How to remove Dual Side Mirror Control Switch on 94-98? - Mustang Evolution
Old 10-06-2009, 09:43 PM   #1
The tab holding the switch panel housing (driver side) broke off and doesn't stay in so I bought a new one to replace it. I had no trouble removing the switch panel housing from the door panel but I cannot for the life of me figure out how to remove the dual side mirror control switch out of the switch panel housing. It's got two tabs that can be pushed in on the top and right side but on the left and bottom it's got two small nubs that prevent me from removing it. There's got to be something simple that I'm missing; I can't believe how much !@#$%&* time I've spent on what should've taken 5 minutes...any help is much appreciated!!!
For reference:
The mirror control switch I'm trying to remove:
The tabs that can be pushed in:
The nubs:
C00LAS1CE is offline   Reply With Quote
Old 10-06-2009, 11:55 PM   #2
OsirisGuy's Avatar
Re: How to remove Dual Side Mirror Control Switch on 94-98?
I'm pretty sure those bumps are also tabs, or somehow act as tabs. So while you push in those two big ones, you either have to wiggle the switch out by clearing one bump at a time, or trying to push in all tabs at once and popping it out.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-07-2009, 09:56 PM   #3
Thanks! I pushed down HARD with flat head screwdriver into each of the nubs with the tabs pushed in and it came right out. Now if only I can figure out how to get the door panel switch housing back into the door panel...
Old 10-07-2009, 11:46 PM   #4
OsirisGuy's Avatar
With the door panel switch, unscrew it from the trim piece and you'll have to angle it through the hole that is now left from the removed piece.
OsirisGuy is right
2002 Mustang GT
Old 10-08-2009, 07:21 AM   #5
just take your time and you will figure it out without breaking anything
Side mirror covers, not just the inserts SpectorV 2005-2010 Mustang GT 4 05-27-2008 11:32 AM
how to remove cruise control buttons jimmy_beaner Mustang Audio & Video 7 06-01-2006 01:55 PM
driver's side mirror greenpony02 Mustang Audio & Video 9 03-05-2005 12:51 PM
99-04 driver side mirror SpectorV Mustang Parts for Sale and Wanted 9 02-01-2005 04:01 PM
10:07 AM
