jack stands - Mustang Evolution
Old 10-10-2009, 09:55 AM   #1
04_GT's Avatar
jack stands
Im trying to get up underneath my rear end. Wheres the best spot to jack it up and put the jack stands.
04_GT is offline   Reply With Quote
Old 10-10-2009, 10:11 AM   #2
Region: Nevada
Re: jack stands
I usually jack the car up from under the differential and put the jack stands under each side of the axle
chris098 is offline   Reply With Quote
Old 10-10-2009, 10:43 AM   #3
04_GT's Avatar
Re: jack stands
Ok thats what I thought I just wanted to double check. Thanks
Old 10-10-2009, 10:48 AM   #4
Re: jack stands
Depends on what you are working on. Normally I prefer the jack stands to be on the frame if I'm doing any serious work on the car. If I'm dropping the tranny I'll put the rear stands under the frame and the fronts under the front A-arms.
I jack from the differential on the rear and the front from the K crossover.
Old 10-10-2009, 10:54 AM   #5
MonteCitan's Avatar
Re: jack stands
Exactly, get right under the pumpkin with the jack (unless you're using your spare tire jack to lift the car... Then use the lift point specified in the owners manual)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Jack Daniel's upton7 The Bar 38 04-09-2010 10:38 AM
Not being a Jack*** Matt'sredbeauty Pre-2005 V6 Mustang 10 03-31-2005 02:29 PM
Eval Feature in magazine on stands now...V6Stangs.com MENTIONED! Autobadges.com The Bar 23 09-05-2004 09:29 PM
It stands to reason Ken The Bar 14 10-25-2003 06:32 AM
06:23 PM
