Moving my battery to the trunk...help - Mustang Evolution
Old 08-08-2005, 12:22 PM   #1
Ok, I have picked up a new intercooler resevoir which will replace my battery, so I need to move the battery to the trunk. I have been shopping around, and I am finding it kind of funny how the prices are running. The steeda relocation kit is 199.99, while summit has kits ranging from $42 to $145. Since I don't race at the track, I don't see me needing something that is IHRA certified. The kit I am thinking of is the $42 kit as it comes with the following.
15 in. Length x 9 in. Width x 10 1/2 in. Height
That includes case straps, an H-bar battery hold-down, J-bolts, 20 ft. of positive and 3 ft. of negative cable (both 2-gauge), cable straps, connectors, grommets, and mounting hardware.
That seems like it should serve the purpose. Do any experts out there see and issues with this kit?
Oh, and here is the new IC resevoir...I can't wait to see how it affects my IAT2 temps...and hopefully +HP from it being cooler.
Old 08-08-2005, 02:06 PM   #2
slvr2000stang's Avatar
Re: Moving my battery to the trunk...help
Make sure it vents outside of the trunk.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-08-2005, 02:16 PM   #3
Ok, being un-edumacated about this stuff, and since nothing I have read about it so far discusses venting, in fact a number of kits are sealed boxes, what needs to vent?
Also, anyone have any advice about moving the battery to the trunk. I plan to run the positive wire inside the car, under the carpet, rather than under the car. The battery will be going behind the rear passenger wheel. Other than those two items, any suggestions?
Also, I am thinking of using a solenoid kit to control when the cables are hot. Basically, I am looking at following this recipie...although a good bit of it is greek to me. http://www.modularfords.com/forums/s...ad.php?t=28052
Old 08-08-2005, 02:38 PM   #4
batterys emit hydrogen gas i believe that has to be vented.
Old 08-08-2005, 03:30 PM   #5
Monkey's Avatar
^^not all. if you get a sealed battery box, you don't need to vent it to outside.
Old 08-08-2005, 09:18 PM   #6
01mineralgrey6's Avatar
Whipster has a relocation kit...may want to PM him.
-Tony
'99 cobra 'vert
Might be moving again... n8r The Bar 10 01-31-2006 09:27 AM
Running 2 Gauge from battery to trunk = not fun Brent Mustang Audio & Video 4 05-04-2004 07:00 PM
06:30 PM
