Gears &Speedometer problem??? - Mustang Evolution
Old 10-11-2009, 05:32 AM   #1
arlander344's Avatar
I have a 2003 Mustang GT. I just recently changed the factory 327 gears to 373 gears. I know this throws the speedometer off so I bought a Diablo Predator tuner to correct that and get other performance gains. My problem is I have tuned my Mustang several times now, and yes I have changed the gear setting in the tuner to 373, but my speedometer is still 10 to 12 mph off at 60+. And yes the car still has the factory size of tires. I did not have this problem before I switched gears. Does anyone know what may be going on??? Should I use a different tuner??? Any help would be appreciated.
Thanks.
arlander344 is offline   Reply With Quote
Old 10-11-2009, 02:09 PM   #2
Region: Nevada
Re: Gears &Speedometer problem???
Which tires do you have? You might want to go to the manufacturers website and get the tire revs per mile from there. Sometimes the number is different than the one you may of calculated on your own
chris098 is offline   Reply With Quote
Old 10-11-2009, 03:16 PM   #3
2007STANG's Avatar
Region: West Virgina
whats the web site
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 10-11-2009, 04:12 PM   #4
Region: Nevada
I dont know. Whatever brand name your tire is just google to find their site. Or go to google and put in the name, model, tire size and then add "tire revs per mile" and see what comes up. Or if you just find some sites that sells tires, try to search for your tire and they will usually have the tire revs per mile in the description somewhere
Old 10-12-2009, 07:41 AM   #5
if its that far of the tuner isnt doing its job. Some do revolutions per miles~ or does yours just let you enter in the values. Make sure the overall tire height and such are correct in the entry as those might throw it off.
You can probably get a dallas speedcal unit and plug it in, worked great for my 01 v6, but the tuner should fix it.
Old 10-12-2009, 10:39 AM   #6
Yeah, I figured out it's the tuner after playing around with it yesterday. It lets you enter values for revs per mile on the tires and pre set gear ratios. I had both of those set for my vehicle but it was still off. The Diablo tuner I have came with two tunes, the "Diablo" tune and the "Factory HP" tune. In both you can set any parameters you want. At first I had the Diablo tune in and it worked but when I switched to the Factory HP tune the speedometer was off. Yesterday I switched back to the Diablo tune and its back on again. Apparently there is something wrong with their "Factory HP" tune.
Old 10-12-2009, 12:54 PM   #7
Scut95's Avatar
maybe the factory hp tune still reads the stock gear ratio and not the new 3.73.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
4:10 gears problem/shifts The Darkside Pre-2005 V6 Mustang 15 06-17-2009 09:33 AM
Tuners & Gears Jay Dawg Pre-2005 V6 Mustang 7 06-05-2009 12:01 PM
Amp problem Stumpy Mustang Audio & Video 14 09-11-2006 07:50 PM
98 Speedometer Recalibration Gears? Mustang414 Pre-2005 V6 Mustang 12 06-27-2004 07:48 PM
07:17 AM
