fuel filter help? - Mustang Evolution
Old 08-11-2005, 04:00 PM   #1
01mineralgrey6's Avatar
fuel filter help?
I feel like a n00b, but where the hell is the fuse panel at so i can pull the fuse, so i can change the fuel filter! , I found something up under dash but i don't know which fuse is what, theres no panel or anything. its completely diff. from my v6, but i don't remember to well either.
-Tony
'99 cobra 'vert
Old 08-11-2005, 04:27 PM   #2
slvr2000stang's Avatar
Re: fuel filter help?
Fuel pump fuse is in the box in the engine compartment.
Diagram is in your owners manual.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-11-2005, 04:31 PM   #3
cool!!! Thanks!!
-Tony
'99 cobra 'vert
Old 08-11-2005, 04:55 PM   #4
No problem.
2000 Vert 4R70W
Old 08-11-2005, 07:46 PM   #5
ok i pulled the fuse earlier, and crawled up under the car and i can't get the fittings loose. Is there a special trick to getting the connections loose, how do you use the little things( you probably know what im talking about) but do they just clip on to the fuel filter than you push them up into the fitting? anyways i can't get it loose. when i did my last car they popped right off.i don't know if its just being difficult. or if its just me
-Tony
'99 cobra 'vert
Old 08-11-2005, 08:11 PM   #6
you need a fuel line disconnect tool. A couple of bucks at the parts store.
2000 Vert 4R70W
Old 08-11-2005, 08:36 PM   #7
silverstangboy's Avatar
why did you need to take the fuel pump relay fuse out?
you know the car won't maintain fuel pressure when its not running..
93 mustang notch
~450hp 331 stroker - Sold
Old 08-11-2005, 09:05 PM   #8
Don't know you can relieve system pressure through the schreader valve on the fuel rail.
2000 Vert 4R70W
Old 08-12-2005, 08:43 AM   #9
Rick0636's Avatar
Yeah, what I was going to say exactly, find that shrader valve on the fuel rail, looks like a tire fill valve, get a rag to absorb any gasoline that comes out, push in the valve like you wanted to let air outta the tire, that will let off the pressure.
Old 08-12-2005, 12:24 PM   #10
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
just have something under the filter to catch fuel that is left in it. You would be suprised how much will come out of that little thing!
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 08-12-2005, 03:18 PM   #11
you dont have to take the fuse out, just get "the tool" to take out the fuel filter, some special tool on the newer mustangs.
Pop it out, watch out for gas that will comeout. then put the new one in, and turn car on to check for leaks.
Keep the gas in your filter so you can poor it out to look at it see how bad it is.
Old 08-13-2005, 11:02 AM   #12
didn't know about the valve on the fuel rail...thats kinda cool. I have the special tool needed, I just cant seem to get it to disengage, but a friend came over and helped me out. apparently there was some dirt in the fitting or something? but the new one is on and the fuel coming out of the filter was dirty!!!yuck!
thanks for all the info guys!
-Tony
'99 cobra 'vert
Old 08-13-2005, 09:03 PM   #13
Yeah, I changed mine when I swapped fuel pumps and it was pretty dirty in there, I don't think it had been changed yet and I had 62K miles.
-Adolf Hitler, 1935
Old 08-14-2005, 09:39 AM   #14
MonteCitan's Avatar
haha leave it pressurized.. helps on one side, just shield it with a rag or something.. helps pop it off with the tool..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Fuel filter? OHHitsKB Pre-2005 V6 Mustang 9 07-12-2010 11:19 AM
fuel filter upton7 1996-2004 Mustang GT 18 02-10-2010 07:07 AM
fuel filter 95blackgt 1979-1995 Mustang GT 5 11-11-2008 10:27 PM
99 fuel filter jilly filly Pre-2005 V6 Mustang 6 07-10-2007 11:44 PM
fuel filter HELP project232 Pre-2005 V6 Mustang 3 04-16-2005 07:54 PM
06:58 AM
