I NEED HELP!!! - Mustang Evolution
Old 10-17-2009, 09:45 AM   #1
1998gt's Avatar
Question I NEED HELP!!!
hi i wanted to know the best way to take off the gt4.6 emblem on the side of my car thank you!!!
see ya!!!
1998gt is offline   Reply With Quote
Old 10-17-2009, 09:54 AM   #2
outlawfrog's Avatar
Re: I NEED HELP!!!
flathead screwdriver and a BIG hammer.
naaa...... maybe a less damaging way? lol
I'm not 100% sure, but I'm assuming they are "stuck on". I'm think a heatgun might work, as long as you don't get the paint too hot. But you may want to wait for one of the more knowledgable guys to respond.
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 10-17-2009, 03:14 PM   #3
I liek gramer
WhiteStang99's Avatar
Re: I NEED HELP!!!
They're stuck on with some sort of adhesive AND punched through the metal. If you remove the emblem, it will leave holes in the car, so I wouldn't do it unless you're replacing it with something..
I'd use something plastic with a point to pry it up and some cleaning products (that you know are paint-safe) to get the adhesive off.
Old 10-17-2009, 04:36 PM   #4
67mustang97's Avatar
Region: Vermont
Re: I NEED HELP!!!
Try some dental floss.
Old 10-17-2009, 04:42 PM   #5
I liek gramer
Re: I NEED HELP!!!
^ that's an even better idea.
Old 10-17-2009, 08:58 PM   #6
OsirisGuy's Avatar
Re: I NEED HELP!!!
Use a heat gun or a hair dryer and heat up the emblem a bit so it's pretty warm. Warm enough to gum up/melt adhesive, use your judgment here. I've had held heat guns on spots for times so it may take some time for it to actually do anything to the paint.
When you get it heated up a little use some dental floss or fishing line and slip it between the emblem itself and the surface of the car to cut the adhesive.
To remove the gunk I like to use Goof Off (xylene) sparingly and probably a little elbow grease. I have never had luck with Goo Gone and therefore I do not recommend it.
I am not sure whether there is a guide hole in the fender but you should be prepared to either live with it, plug it up, and put something in the spot just in case when you take it off it is there. I want to say that the fender emblems have guide holes, the trunk emblem is just the emblem piece (no guide holes).
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-18-2009, 02:01 AM   #7
Cobra GT's Avatar
Re: I NEED HELP!!!
i liked the hammer and screwdriver method better
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 10-19-2009, 06:32 PM   #8
1998gt's Avatar
Re: I NEED HELP!!!
thank you all so much i think with all your advice i am going to use my heat gun and some dental floss and put new emblems that are chrome and just say 4.6 Thanks!!!
see ya!!!
Old 10-19-2009, 06:51 PM   #9
Re: I NEED HELP!!!
I did this to my car and replaced them with the new edge style gt emblems and Goo Gone worked real good for me. Just a little pressure prying the emblems and they come off with no issues.
96 GT- Who knows what's in it.
03:44 AM
