Lowering my 04... - Mustang Evolution
Old 10-20-2009, 05:33 PM   #1
04SonicBlueGT's Avatar
Lowering my 04...
Hello, im new and i was wondering if anyone can help me. i am about out to buy some black bullitts, 17X9 in the front and 17X10.5 in the rear. and i was wondering if i needed anything else then the springs... i was going to go with H&R Super Sport from american muscle.
H&R Super Sport Springs (96-04 GT/V6) at AmericanMuscle.com - Free Shipping!
my car is pretty new. it has 42,000 miles so i dont know if i need to really change anything else then the springs.
04SonicBlueGT is offline   Reply With Quote
Old 10-20-2009, 05:40 PM   #2
Re: Lowering my 04...
welcome to ya :thumbs2:
I would consider cast and camber plates along with your springs. They will prevent any uneven tread wear/cupping to those new tires on those bullitts. Usually cc plates are recommended for any drop beyond 1" on the 99-04's. Maximum Motorsports are some of the best out there, I've heard very good things about them.
Ford Mustang Caster Camber Plates at AmericanMuscle.com - Free Shipping!
If you have the cash, you could look into some shocks and struts since you're tearing that area apart. But as you said, the car's pretty new, so they're not necessary. Your stock ones should be fine for a while.
P.S. Good choice on the black bullitts...they look very good on our color cars
And post up some pics of that sonic blue GT, we don't have too many of them on the site.
Old 10-20-2009, 06:07 PM   #3
y would i need camber plates? and i only have 1 picture on my fone of it before i got tints and Mach 1 Chin Spoiler.
Old 10-20-2009, 06:20 PM   #4
As the car is lowered by the aftermarket springs, the camber angle (how the tire leans when looking at the front of the car) is changed from being vertical (or close to, if you notice how the wheels sit when fully locked in either direction). This change is either inward or outward, causing your tires to wear unevenly.
If you were dropping the car .75" or 1", you could probably fix the camber by just an alignment. But when dropping larger amounts (+1.5") the cc plates are needed on the front shock towers. So basically, it you don't want to have to replace the front tires after 10k miles, I'd get the cc plates.
Old 10-20-2009, 06:31 PM   #5
I liek gramer
WhiteStang99's Avatar
Instead of hitting the pavement like this: |
Your tires will hit the pavement like this: / or like this: \
Which basically means you will wear the inside of your tires your tires completely bald before you get any noticeable wear on the outside. CC plates are well worth it. I had Maximum Motorsports Caster/Camber plates on my 99 with a 1.5" drop and they were perfect.
Old 10-20-2009, 06:46 PM   #6
i didn't think just lowering my car will be so expensive... lol geeeez. well how does the camber plate work? i replace the sotck 1 with the MM and how do i fix the wheel so it can hit the floor straight?
Old 10-20-2009, 07:10 PM   #7
Those are about the going prices for springs and cc plates. The overall cost is way more if you have them installed by a shop.
The springs/cc plates can be installed in a day or less if you have the patience, tools (impact gun), and mechanical know-how.
Here's an article I found a little while ago. This install of cc plates was done on an 02 GT.
How To Install Caster/Camber Plates - Mustang Monthly Magazine
Old 10-20-2009, 07:27 PM   #8
yeah i see but all i need to do is put them on ... i dont need to mess with it to aline it myself? all i need is to get an alignment at a shop?
thanks for the advise my the way. great help
Old 10-20-2009, 07:47 PM   #9
Region: Iowa
You can't go wrong with the MM plates. We have sold and installed a lot of these and have not had a failure yet. MM also offers limited lifetime warranty on the parts. The H&R springs are a nice spring as well.
As mentioned above, with that much of drop, you may have trouble getting the car back 'in spec' for alignment and the CC plates will allow for greater adjustment. Track and auto-x people like them as well as they can adjust the caster-camber for track use.
Any alignment shop should be able to align the car using the plates.
John@NQS is offline   Reply With Quote
Old 10-21-2009, 06:36 AM   #10
Oh ok so with just installing the MM plates myself and getting an alignment at a local shop will do the trick? and i will not have any other problems?
Old 10-21-2009, 07:21 AM   #11
look at pics in my signature (link to them in there) I have H&R race. I would recommend them if you want good handling with a good drop. The sports drop you to much IMO... I am at my limit~ anymore would be to low for looks and driving ( at least to me)
you will need CC plates and in the future springs/shocks. I recommend 4 bolt Maximum motorsport plates.
Old 10-21-2009, 08:51 AM   #12
edross's Avatar
like SpectorV said H&R race give you plenty of drop, btw american muscle actually posted a couple pics of my car on there site for the H&R race lowering springs, is that cool or what
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 10-21-2009, 10:06 AM   #13
Well H&R Race Springs for GT's its only a 1.25" in the front and only 1" in the rear... no offence but thats nothing. not worth the drop if its that small. and SpectorV its different for Cobras its 1.6" in front and 1.5" in the rear. thats about what i want. H&R super sports give me 1.75" in front and 1.5" or 1.6" in the rear.
always im going to have 17" wheels not 18" so it looks like i have a huge wheel cap. and that isnt not what i want at all
Old 10-21-2009, 10:07 AM   #14
Another thing i am doing it for looks only im not going to be turning at 30-40 MPH lol
Old 10-21-2009, 03:11 PM   #15
I liek gramer
The caster/camber plates simply allow for more adjustment than your stock setup. I don't think it's possible to have it aligned properly with a stock setup and a 1.5" drop from springs.
I had my new springs put on, then put on the caster camber plates, and took it straight to a shop, who aligned it for me with no problems.
Old 10-21-2009, 03:36 PM   #16
hmm interesting, so the Race doesnt drop as much on GT's hmm oh well then the super sports sound about right, you can always run poly isolators to raise it up a tad~
you can do springs and see if the alignment is ok, its a risk as if its not the cc plates are about the same amount of work as springs and its easy to put them in while doing it~ just something you will have to decide about.
Old 10-21-2009, 06:39 PM   #17
I mean I was going to go with my stock isolators. Like I said my car has pretty low miles, and so what ur suggesting is that I do the springs first to see if an rubbing occurse? If it does then I get MM plates?
Old 10-21-2009, 07:19 PM   #18
go ahead and get the c/c plates, you will need them. period.
Old 10-21-2009, 10:04 PM   #19
Hey I saw your car on the American Muscle site. Looks good man, after seeing the drop on your car, I'm probably going to get those H&R's...they look good.
Old 10-22-2009, 05:38 AM   #20
edross's Avatar
thanks Sonicpony, it didnt look low enough when i took it off the stands but they settle nicely after about 200 miles
Old 10-22-2009, 09:02 AM   #21
also note on MM's cc plates they allow the strut to raise up some more to offset the drop, as you lower the car more of the strut shaft is in the strut body right, makes since.
So.. the lower you go the more the strut shaft will be in the strut body all the time, this wears it out a little faster. The MM plates raise it up about an inch~ to help offset some of this.
Old 10-22-2009, 04:48 PM   #22
Nice nice. thanks for the help SpectorV ur great help man. i will buy my Bullitts hopefully tomorrow friday. and then get those MM plates to then buy the H&Rs
Old 10-23-2009, 12:31 PM   #23
sounds good, do a cc plate install how to (take a ton of pics mainly) we could use it on the site.
Lowering?? Gt.Vert 1996-2004 Mustang GT 9 10-12-2009 07:12 AM
Lowering my 04 GT Talon 1996-2004 Mustang GT 13 07-15-2009 08:02 PM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 11:04 AM
lowering? Kryptonite Mustang Audio & Video 6 10-23-2006 08:15 PM
Lowering? 19ClearCobra96 1996-2004 Mustang GT 14 05-16-2005 06:54 PM
10:49 PM
