overheating after changing the oil filter adapter - Mustang Evolution
Old 10-21-2009, 05:00 AM   #1
Greetings to all
I recently changed the oil filter adapter on my ford mustang Mach I 2003'
I kept the radiator cap off waiting for it to draw into the block so i could add fluid. This never seemed to happen. I thought i would drive it for a bit heat it to the point it would draw. Big Mistake ! heat shot out of normal range started labor knocking. I could use a little help here guys. Any would be greatly appreciated. attempt 1 changed thermostat , didnt help. tried burping tried ,,believe it or not,,a shop vac,,still in trouble here
Thanks to all and have a nice day
2003stangmachI is offline   Reply With Quote
Old 10-21-2009, 08:58 PM   #2
Re: overheating after changing the oil filter adapter
wut?
Old 10-21-2009, 09:00 PM   #3
There is a special refill procedure for the 4v ford engines and coolant. I'm trying to figure out why you needed to add coolant for an oil filter adapter...
Old 10-21-2009, 10:17 PM   #4
hottcobra's Avatar
the oil filter adapter has a coolant passage in it. that's why he lost coolant.
Like said before you need to look up and do the coolant air bleed for the ford 4V engine.
here you go:
Cobra, Mach 1, Ford 4.6L DOHC Coolant Refill & Burp Procedure by Reische Performance Products
Old 10-21-2009, 11:38 PM   #5
here you go:
Well holy crap...I didn't realize that. Nice call man.
Old 10-22-2009, 10:10 AM   #6
If I was you and didnt know much about cars I would take my vehicle to a ford dealer. They can drain and fill the coolant (not just drain the radiator but also drain the engine itself) and use a vacuum system to suck the air out of the coolant track and then they can release the vacuum and it will pull the coolant into the engine. Works quite well.
I have NO idea how an oil filter got into this mix~ unless by adaptor you are talking about the stock oil cooler (not sure if mach 1's have this). They can become loose and should be tightened. Also note to never over tighten your oil filter as this will help it start leaking.
Old 10-22-2009, 11:10 PM   #7
greetings
many thanks to all who replied. Original problem was an oil leak behind where the filter mounts. Replaced the oil filter adapter gasket and the problems ensued. And yes you are correct it has a coolant port. I filled the coolant through the air bleeder and kept on bleeding the air out and forcing it out with pressure through the expansion tank. I still may take it to the dealer and have them use that 350 dollar vac deal to get the system completely right.
Thank you all again for your timely response to my problem.
Old 10-23-2009, 01:29 PM   #8
when I had them vac seal mine it cost me 100 bucks
Old 10-29-2009, 09:26 AM   #9
slostang's Avatar
This is very simple process you can do yourself at home. I've done it serveral times without issue. The procedure is outlined in your user's manual also.
First remove the cross over cap and radiator cap. Next pour coolant solution in through the cross over until you are at the top of the fill line on the radiator tank. Now install the cap on the radiator tank. Continue to fill water through the cross over until it is full. Replace the cross over cap. Start the car and allow it to come up to operating temperature (needle in the middle of the stock gauge). Shut the car off and let it cool down to ambient. Remove the cross over cap and fill it back up. Turn the car on and bring it back up to operating temperature.
Continue this process until you remove the cross over cap and it is full after the car has cooled down after one of these heat cycles.
Hi Rob
slostang is offline   Reply With Quote
Changing the fuel filter electricstang Pre-2005 V6 Mustang 4 05-08-2006 12:16 PM
About changing oil... Ibanezplayer272 Pre-2005 V6 Mustang 21 02-23-2006 10:33 PM
Changing Oil Ques. douGT 1996-2004 Mustang GT 14 05-01-2005 08:55 PM
Parts for sale: gauge, fuel acc., filter adapter, MAF,bumper Mus35th Mustang Parts for Sale and Wanted 7 08-31-2004 02:58 PM
10:56 PM
