my 96 cobra dies when applying brakes. any ideas? - Mustang Evolution
Old 10-22-2009, 08:11 PM   #1
Alright I bought my 96 cobra that has been no oped for a 1 1/2 yrs. The problem I am running into is the car dies when I apply the brakes any idea's?:
sp1ke24 is offline   Reply With Quote
Old 10-22-2009, 09:01 PM   #2
outlawfrog's Avatar
Re: my 96 cobra dies when applying brakes. any ideas?
ANYTIME you apply brakes? Or just when you are at idle to stop?
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 10-22-2009, 09:05 PM   #3
It will die in gear or in neutral coming into a stop.
Old 10-22-2009, 09:15 PM   #4
outlawfrog's Avatar
I'm not sure what the other guys will say, but I suggest starting with the throttle position sensor. It should be around 30-40 bucks. I had an 87 T-bird with the 5.0, and it had sporatic idle probs. Sometimes at a light, it'd just die. At other times, it'd idle up. The day that I was sitting in the drive-thru at Hardee's, and I had to turn the key off to stop the burn-out from a high *** idle.......I swapped the TPS. No more probs after that.
Old 10-23-2009, 12:24 PM   #5
could be the IAC (idle bypass valve) they go bad and the car wont idle, its a round cylinder thing on the throttle body or on the upper intake near the throttle body~ that may be the issue.
Old 10-23-2009, 07:37 PM   #6
If I read your post correctly, the car sat for a year and a half before you bought it; correct? I'm not sure about mid-90s Fords, but I had a 93 Lumina that would lose the engine parameters whenever the battery was disconnected. For 3 or 4 drive cycles, the car would stall when stopping. It always started right back up. The computer had to "re-learn" the parameters for engine operation. This may be the case with your car if the battery was dead or if it did sit for so long.
MetallicMist is offline   Reply With Quote
Old 10-25-2009, 03:06 PM   #7
67mustang97's Avatar
Region: Vermont
Have you replaced your fuel filter?
Old 10-25-2009, 05:02 PM   #8
JoeyR's Avatar
Region: Oregon
Send a message via MSN to JoeyR
+1 for replacing your idle bypass valve and fuel filter, even if there not the source of the problem, they will drastically help the way your car runs if they had never been replaced. you also may want to clean your Mass-Air-Flow sensor.
2000 Mustang GT, SCT Tuner, K&N Cold-Air-Intake, BBK Short Throw, FR 3.73's, PaceSetter Longtubes w/3" streight pipe w/ resonators
JoeyR is offline   Reply With Quote
Old 10-26-2009, 07:31 AM   #9
yea normal upkeep like fuel filter, air filter, coolant, trans fluid, and such can all mess with normal driving over time
Some pics of my new cobra brakes.... timpryor Pictures and Videos 34 06-30-2006 04:15 PM
1998 Cobra R brakes on ebay! SpectorV The Bar 12 12-18-2005 04:01 PM
stock front brakes, cobra rears...bad? tedness Pre-2005 V6 Mustang 6 10-07-2005 06:23 PM
cobra or gt brakes jedwards242000 Pre-2005 V6 Mustang 6 05-03-2005 02:08 AM
Ever Wonder why they say you need 17 inch rims for Cobra brakes? Rick0636 Mustang Audio & Video 12 04-10-2004 09:09 PM
02:58 AM
