01 gt miss? fuel? any ideas?.... - Mustang Evolution
Old 10-25-2009, 04:33 PM   #1
Question 01 gt miss? fuel? any ideas?....
hey on a 01 gt feels like it is missing but i have checked all cylinders and have no miss possibly starving for fuel? only noticeable really when accelerating car stalled on me once seems like fuel any ideas? thanks
saleenman is offline   Reply With Quote
Old 10-25-2009, 04:35 PM   #2
67mustang97's Avatar
Region: Vermont
Re: 01 gt miss? fuel? any ideas?....
Is your cel on?
Old 10-25-2009, 05:02 PM   #3
no cel
Old 10-26-2009, 06:45 AM   #4
edross's Avatar
did you check the sparkplugs?
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 10-26-2009, 09:18 AM   #5
new plugs about a month ago.....pulled clip on all coils and all cylinders are firing......im gunna change out the fuel filter and c what happpens
Old 10-26-2009, 09:20 AM   #6
OsirisGuy's Avatar
What's the car idling at. I want to say the TPS (it's the answer I always resort to whether it is or not).
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-26-2009, 10:44 AM   #7
idle is good and breaks up when accelerating ...... maybe clogged injector?
Old 10-26-2009, 11:54 AM   #8
no luck with the fuel filter change .... did throw a code a p0300 random misfire.....all cylinders are firing ? what next lol
Old 10-26-2009, 02:07 PM   #9
Region: Vermont
I'm not sure maybe you have a weak coil? When you changed your plugs did you find any water or moisture under the coils?
Old 10-26-2009, 02:16 PM   #10
no everything seemed to be ok it was a p0300 now while i was driving it a p0303 came up cylinder 3 misfire guess change the coil and check the plug..
Old 10-26-2009, 02:18 PM   #11
Region: Vermont
You could try to swap a couple of coils and see if you get another cylinder misfire.
Old 10-26-2009, 02:24 PM   #12
thanks good idea
Old 10-26-2009, 10:28 PM   #13
Did you gap your new plugs correctly?
ThaWill is offline   Reply With Quote
Old 10-27-2009, 05:06 PM   #14
Region: Vermont
Any luck yet?
Old 10-31-2009, 02:12 PM   #15
coil num one bit the dust and caudsed random misfires thank you
Old 10-31-2009, 06:13 PM   #16
Region: Vermont
Glad we could help.
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Sometimes I miss her... MarkuzLS1 The Bar 23 11-22-2007 02:19 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
Miss Alabama now Miss America 2005 Brent The Bar 16 09-20-2004 04:44 PM
04:52 PM
