10-27-2009, 08:02 PM
#1 | | Registered User
| Need Help on Interior Paint
Hi guys im new here so Howdy! I just upgraded from a v6 to a v8 last saturday! The car is black and i want to put as much black on the car as possible. Therefor the interior seemed like a reasonable upgrade for the price so thats first. I need to know what kind of paint to buy to paint every single plastic piece in the car and anything else i will need! I am 16 and really know nothing about painting so any tips would be great! I was also thinking about accenting it with a dark red? Let me know what you think
10-27-2009, 09:35 PM
#2 | | Legacy Member
| Re: Need Help on Interior Paint
Check out Late Model Restoration, they have color matching dye that will make it look original, and at a cheap price. I tried somerecently and it works great. They also have instructions on their page to help you out.
96 GT- Who knows what's in it.
10-28-2009, 07:26 AM
#3 | | Terminator Owner
yea you can get interior dye that will work great, but its a TON of work.
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
10-29-2009, 10:09 AM
#4 | | Registered User
While Dye is the best route, your next option would be spray paint.
Pick up a few cans of Krylon Fusion in your color choice. Take out the trim you want to paint and clean it well with some Simple Green (and make sure it's dry), then wipe it down with some Isopropyl (rubbing alcohol) and let it dry (will take only a minute or two for the alcohol). Then you can go and paint it.
Just follow the directions on the can. When you paint you want to remember to use a sweeping motion and paint in layers. The can doesn't have to be right on top when painting leave some distance. So do a first coat, you'll still see some of the original color but that's okay. Let it dry and give it another coat. Repeat as necessary. If you are too heavy on the paint it will run and drip and come out nasty looking.
The usualy parts people paint on these cars is the plastic on the door that houses the window controls and the trim around the radio (and don't forget to pop out the vents!) all of which is very easy to remove. Some people will go as far as to paint the whole top half of the dash, the pony and "Mustang" on the steering wheel and dash (respectively). If you want you can paint the trim around the gauges and parts of the gauges as well.
__________________ Quote:
Originally Posted by MetallicMist OsirisGuy is correct | Quote:
Originally Posted by stangaroo OsirisGuy is right | 2002 Mustang GT
10-29-2009, 10:21 AM
#5 | | Terminator Owner
never start spraying over a part, always off to the side then go across the part. Little droplets can build up and go flying off when you start spraying and if its over a part... they get on the part.
10-29-2009, 06:19 PM
#6 | | Registered User
Thanx guys appreciate it! Would I have to worry about the paint fading in the future, and would i have to prime it because many articles I have read said to prime it.
10-30-2009, 06:48 AM
#7 | | Registered User
Not sure if the Krylon Fusion is their vinyl paint, but I think that's what you want to use. It's formulated for plastics and will give you a better finish than paint formulated for metal or wood. I used some metallic black vinyl paint on the grill of my old '97 Sierra and it looked very good and it didn't fade.
OsirisGuy is correct; Fusion is the paint to use. What can I say? I'm old...
10-30-2009, 09:21 AM
#8 | | Registered User
| Re: Need Help on Interior Paint Quote:
Originally Posted by MetallicMist OsirisGuy is correct | And don't you forget it!
The paint should hold up for years, especially if done correctly. As for priming I wouldn't worry about it. If you are painting black on black than it will be no big deal. If you are painting a lighter color over a dark color, let's say yellow paint on black trim than I would lean towards picking up a can of primer as well just so the black won't bleed through.
Otherwise the rubbing alcohol will prep the surface for paint. If you want you can also throw a coat or two of clear coat on there. I believe Krylon also makes a UV protectant paint.
10-30-2009, 02:03 PM
#9 | | Registered User
Alright thank you guys ill make sure to post up some pictures of my completly redone interior when its done!
10-30-2009, 03:20 PM
#10 | | Registered User
Originally Posted by OsirisGuy And don't you forget it!  | I'll try not to!!! Notice I said "try"...:chin:
11-13-2009, 01:50 PM
#11 | | Registered User
I did a touch up on the interior of my 2002 GT. Got the spray paint from LMR and basically followed the steps Osiris outlined. Just be sure to use a lot of light coats and allow plenty of drying time between coats. Mine looks like new stock!
Jim
__________________  Jim Wyche:Senior Citizen. 1992 Mustang GT with a few mods. See webpage http://web.mac.com/jwyche or my garage. 2002 Mustang GT with a few mods. Collegedale, Tennessee.
12-21-2009, 03:17 PM
#12 | | Registered User
use t.s.p. tri sodium phosphate
can buy at any hardware store, come in pouch then add water to it this cleans all grease off
then use wax and grease remover to get more grime off
then use adhesion promoter (dupli color) comes in can
then vinyl and fabric primer and paint use lots of light coats, some you can even add clear coats
12-27-2009, 09:47 AM
#13 | | Registered User
i got the stuff from duplicolor. think it's called vinyl & fabric paint(?) anyway, works great, & the pieces i painted black look like it came from the factory that way. i still have more to paint, but when i do i'm replacing the carpet, mats etc...just need to be paitent & it'll turn out great. good luck.
12-27-2009, 10:06 AM
#14 | | Loc: Austin,TX
Use a paint brush and if you are not satisfied pour a can of paint right over the dash and rub it in with your hands.........just kidding. ^^^listen to the guys above,very good advice.
---Dan--
2011 5.0 6MT Black on black premium,3.73 option and some go fast goodies!
*POSTING RULE #1*
Before you post a question, use the forum search feature to determine whether your topic has already been covered. http://www.mustangevolution.com/foru...ork&page=rules |
