power issues - Mustang Evolution
View Poll Results: What is wrong?
Battery 0 0%
Alternator 1 33.33%
Sell the car and get a neon. 2 66.67%
Voters: 3. You may not vote on this poll
Old 09-10-2005, 04:46 AM   #1
Warfire80's Avatar
Send a message via MSN to Warfire80
power issues
This morning I was driving my car to work and as I rolled the windows up and down the headlights would flicker, so I thought nothing of it until a little while later when I had to roll the window down and the abs light came on. Then the whole car lost power (about 45mph, cruising down to stop, clutch out, gear in neutral) gauges went dark, stereo cut off etc.... not 5 seconds later everything cut back on, all the gauges turned on and stereo came on etc... All I had to do was restart the car and continue on about my business, so I get to work, stop the car and it is idling fine, so I turned it off got out and started walking away when I hit the lock button on my key fob and didnt hear the familiar honk you get, so I turned around walked back to the car and it locked but didnt arm the alarm(factory alarm) so I closed the door hit the button again and nothing this time, I didnt have time to do anything else so I manually locked the car and left. Sooooo after that long story I need some help.
2007 Honda Civic EX
2003 Dodge Ram Hemi 4x4
by Lawrence Bell
Show me a man who cannot bother to do little things and I'll show you a man who cannot be trusted to do big things
Warfire80 is offline   Reply With Quote
Old 09-10-2005, 09:31 AM   #2
Rick0636's Avatar
Re: power issues
Man, hard to say, but I doubt it is the battery or the alternator, more like a short somewhere maybe??
Old 09-10-2005, 10:35 AM   #3
Re: power issues
It sounds like it could be a short running from the alternator..hence the reason it sometimes works, and sometimes doesn't.
Old 09-10-2005, 11:52 AM   #4
Warfire80's Avatar
Re: power issues
I went back out to the car and started it up fine after about an hour, but the key fob still wouldnt register with the lock and even pushing the buttons for the lock inside the car didnt work, but car ran fine, turned a/c on wipers etc... and didnt stall or anything.
2007 Honda Civic EX
by Lawrence Bell
Old 09-10-2005, 11:58 AM   #5
Re: power issues
Sounds like a short somewhere to me, especially after what you just posted.
Old 09-10-2005, 12:22 PM   #6
Warfire80's Avatar
Re: power issues
ok, went back out again and everything is working, key fob, door locks (inside car) etc... now I have no idea what is going on. I think I am just going to take it to auto zone and have them check my battery and alternator to see if it is working properly.
2007 Honda Civic EX
by Lawrence Bell
Old 09-11-2005, 10:53 AM   #7
Rick0636's Avatar
Re: power issues
If there is anything wrong with your battery or alternator, I would be seriously surprized.
Old 09-12-2005, 01:05 PM   #8
Re: power issues
its a short most likely in your dash harness.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 09-19-2005, 08:53 PM   #9
Fishers Stang's Avatar
Re: power issues
check your connections to your alt, batt, and your starter (yes i said starter) other then that take it to ford and see whats up
Charles
Old 09-19-2005, 11:50 PM   #10
Thomas91169's Avatar
Re: power issues
95% of the time with problems like you stated, its the alt.
take that sucker off and take it to autozone and get it tested. im betting its the alt.
-Thomas-
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
Issues with 03 GT 03YellowGT 1996-2004 Mustang GT 7 12-05-2005 10:57 AM
So I have some issues... bluemustang The Bar 14 02-21-2005 04:13 PM
power steering issues WhiteStang99 Pre-2005 V6 Mustang 16 06-22-2004 06:08 AM
I have serious issues n8r The Bar 23 10-17-2003 12:33 PM
05:27 AM
