Strut/Shock info - Mustang Evolution
Old 11-24-2009, 12:16 AM   #1
Strut/Shock info
Hey guys I'm back again. Anyways I've been thinking about upgrading the shocks and struts on my car and need a little help deciding what to get. I would love to get Billsteins, but a little out of my price range at the moment. Anyways I am considering getting the blue Tokicos. I would like something that offers better proformance without feeling too harsh. If anyone has experience with these struts/shocks please let me know.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 11-24-2009, 10:59 AM   #2
Re: Strut/Shock info
If you already have springs (around 600lbs front/300lbs rear) the mach 1 spec tokicos will work great. They are around 200 a set front/rear.
Old 11-24-2009, 02:21 PM   #3
I only have stock springs at the moment.
Old 11-24-2009, 02:54 PM   #4
well its a good idea to do springs at the same time due to they basically are the same type of install
Old 11-24-2009, 04:33 PM   #5
Got any spring recomendations? Eibach, H&R, or the ones from Ford Racing?
Old 11-24-2009, 05:15 PM   #6
Actually this whole kit seems like the better deal
Ford Racing Performance Parts []
Old 11-25-2009, 07:43 AM   #7
Ford racing C springs is a good deal for a good spring, they are just a linear rate spring and some want more of a drop.
If it was me I personally would go H&R race (or H&R sport for a lower drop), Eibach, or Ford C springs. The H&R will be more performance oriented and are progressive rate vs linear (progressive = tighter coils as they go to the bottom so the more you push the harder it pushes back this lets you have a higher spring rate (max) and a better ride) while not pushing it hard)
I had C springs and they are fine but the drop was not quite enough... they can be cut though to give you the right drop you cant cut a progressive spring usually.
Also... if you was to get say a spring that lowered you a touch to much you can just buy a set of urethane isolators and it will lift it back up, you can put just the top or bottom in and even it out how you wish~
87-93 shock questions cowboy72 1979-1995 Mustang GT 9 06-27-2007 02:16 PM
NWS...The Shock Absorber JROC The Bar 14 02-28-2007 02:01 AM
Guess This Would Shock Any Hunter bluemustang The Bar 11 12-16-2006 06:57 AM
Shock & Strut ? mrvMustang Pre-2005 V6 Mustang 19 06-17-2006 10:21 PM
whats the best shock strut? powerhungry966 Pre-2005 V6 Mustang 7 04-09-2006 12:48 AM
10:12 AM
