motor noise - Mustang Evolution
Old 12-01-2009, 09:41 PM   #1
Region: West Virgina
Cool motor noise
I have a 98 cobra with 82K on it it runs great other than some motor noise which sound like a spun rod bearing or a bad wrist pin.The car makes the noise when you rev it,not at idle,and constantly at about 2000-2400 rpms.I am going to tear into this motor but would like to get some suggestions of what this noise might be.If anybody has any suggestions I am always open for ideas.Thanks for the help and you can email me here or at autolover70@yahoo.com
luvmystallion is offline   Reply With Quote
Old 12-02-2009, 09:07 AM   #2
Re: motor noise
you can get someone to inspect the cylinders before you tear it down to look for damage, just have to lower each piston and check the walls~ or you can drop the motor and check the block with the pan off~ you never know but it does sound like what you said.
Old 12-02-2009, 09:19 AM   #3
Re: motor noise
which one a spun rod bearing or a bad wrist pin
Old 12-08-2009, 03:35 PM   #4
Re: motor noise
hey not to question your knowledge lol but i thought i had the same problem but it was the ac comp. the bearing on it was gioing and the noise traveled just check it out first
03 Yellow Stang is offline   Reply With Quote
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
popping noise??? girlandherstang Pre-2005 V6 Mustang 8 06-28-2008 10:20 AM
Strange Noise HELP 19ClearCobra96 1996-2004 Mustang GT 10 09-26-2005 01:29 AM
wierd noise InVaDeR Pre-2005 V6 Mustang 16 09-21-2004 05:31 PM
02:20 PM
