Gears and Drive train - Mustang Evolution
Old 12-05-2005, 07:59 PM   #1
Guys i have a 2002 mustang gt v8, my mechanic recommended the ford racing drive shaft what do some of you guys recommend, i also want to add gears to my car. I have been told my mustang owners, 410's 411's 373's but i really cant decide which is best. i would like to have my car set for 1/4 miles if that helps. please give me some advice, thanks
XxV8 MuStAnGxX is offline   Reply With Quote
Old 12-05-2005, 08:14 PM   #2
Re: Gears and Drive train
What tranny do you have? Also, if you're talking about an aluminum driveshaft...it really isn't gonna give you enough gains for the amount of money you're looking at spending. Not worth it to me, but some ppl go that route.
Old 12-05-2005, 09:06 PM   #3
aluminumk drive shaft is not worth it
as for gear do 4.10's but keep in mind you will need a chip to correct your speedo if you have an auto
Old 12-06-2005, 04:24 PM   #4
aluminum driveshafts are one of those mods you do at the end of the cars modifications, its not really noticable. it smooths the car out and may add a couple hp/tq from the gain of a more efficient driveline (the driveshaft) it helps rotational mass by 10lbs, which is about 100lbs of dead weight. In the end you will get better gasmilage... and get more driveline clunking noise when you are turning really slow and what not.
I would go with 3.73 gears for daily driving, you have 3.27s stock. Go with OEM ford gears they are very good and wont whine (like richmond) if installed CORRECTLY... that is the key term... get a warranty in WRITING for whine and breakage for X amount of miles (try to get 10k or so miles on warranty)
the gears will cost under 200 and the install can run from 200 to 500... just pay extra to get a better job. For calibration of the speedo you can probably run a dallas speedcal, easy to install, and you wont have to spend 400 bucks on a chip. I have the speedcal and it works great.
Old 12-26-2005, 05:02 PM   #5
would i need a chip for an stock 5sp trans
Old 12-26-2005, 05:03 PM   #6
No, you can run a speedcal as spectorv said in his post.
Old 12-26-2005, 05:05 PM   #7
Which is the easiest thing to do but more expensive than buying the appropriate gear for your transmission
Old 12-26-2005, 08:06 PM   #8
what is a speedcal?
Old 12-26-2005, 08:11 PM   #9
http://dallasmustang.com/page/produc...&product=9910T
Old 12-28-2005, 09:30 PM   #10
DarkShadow's Avatar
Send a message via AIM to DarkShadow
It sounds to me like that guy at the shop has a spare shaft laying around that he wants to get rid of. It's not worth it.
DarkShadow is offline   Reply With Quote
Old 01-21-2006, 03:06 PM   #11
xtremejc's Avatar
Don't fear the gear my friend... Go for the anything that has a 4 digit in front and you will be happy. Get the speed cal and forget about the DS...
JC
1997 Rio Red TT Cobra
2003 Mineral Gray Whipple Powered Cobra
2006 Redfire A/T Mustang GT
xtremejc is offline   Reply With Quote
Old 01-22-2006, 02:10 AM   #12
Thomas91169's Avatar
i would only replace the DS if the current unit was going out, as a direct ford replacement is almost double the cost of a better, lighter aftermarket one.
as for gears, anything more than 3.73's will suffice. 4.1's will be nice on a naturally aspirated(non forced induction/nitrous) manual, or 4.30's on a naturalyy aspirated automatic. if boosted/nitrous fed, id do either 3.73's or 3.90's, youll want the longer gear to take advantage of the more power to move more distance.
right now i am basically stock(save for intake, tuner and exhaust, few boltons) and im going with 3.90's cause sometime in the future i plan on either nitrous feeding her or boosting(vortech) her. either way, ill have the best of both worlds of the low down launch accel of the 4.1's and the top end of the 3.73's when i go with the middle ground 3.90's.
-Thomas-
Old 01-22-2006, 08:16 AM   #13
xtremejc's Avatar
For whatever it's worth stay away from the Motive brand gear sets. I have tried every FMS gear set (3.27, 3.55, 3.73, 4.10, 4.30, 4.56, 4.88) and even a set of Motive 3.90's gears over the last few years and you could not get me to use anything other than the FMS gearsets. The FORD gears are the highest quality gear available, period... Get the 4.10 for your GT and you will love them even with N2O, boost, or just NA.
Just my 2 cents...
JC
Old 01-22-2006, 11:10 AM   #14
I agree with spector. Stay away from richmond. I wish I got the 3:90's instead of my 3:73's, cause I plan on getting a six speed soon.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 01-22-2006, 11:57 AM   #15
I liek gramer
WhiteStang99's Avatar
That theory doesn't apply to the driveshaft, that only works with wheels + tires if I'm not mistaken.
Old 01-27-2006, 02:42 PM   #16
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
It applies to all rotating mass
I'd skip the speedcal and get a tuner, then you have that later on if you decide to do any major modifications. Also, I'd get 4.10 gears if you won't have a blower anytime in the future.
4.11 is a chevy gear
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 01-27-2006, 02:43 PM   #17
Oh, and nitrous loves the gear by the way
-Adolf Hitler, 1935
Old 02-04-2006, 07:55 PM   #18
MonteCitan's Avatar
4.10s!! I loved mine for the 2 minutes I got to use them.. 3.73s won't be all that much of an improvement over your stock 3.27s.. Your RPMs will be in the 2800ish range at 75 MPH
Next I'd get a good drag radial, unless you have to drive often in the snow.. - my nittos worked superbly on the street (not so at the track but still) it'd slip then grip, and it'd grab between shifts too, I loved it.
If you have not done it yet, get a short throw shifter.. I've tried both pro 5.0 and steeda.. I preferred the steeda (position-wise) just personal opinion though
From there on.. the mods you do will not net really noticeable gains (perhaps in 1/4 mile trim, but I wasn't really ever able to feel an SOP difference with my mods.. my diablosport definitely sparked top-end a bit, but not by much.. and it required premium fuel)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
It sounded like a freight train!!! MarkuzLS1 The Bar 4 08-05-2009 12:18 PM
drive train question. Paincake1 Pre-2005 V6 Mustang 2 09-05-2008 11:41 PM
Fast French Train: MarkuzLS1 The Bar 6 04-03-2007 09:33 PM
18 wheeler - 0... Train - 1 Zim Pictures and Videos 7 09-12-2006 12:12 PM
Stock drive train specs and modding advice for V6 Mustangs oaktonarcher Pre-2005 V6 Mustang 7 06-28-2005 01:49 PM
05:19 PM
