suspension.. - Mustang Evolution
Old 12-25-2009, 01:48 AM   #1
suspension..
gonna get some H&R lowering springs for my 02 gt since its in my price range, do i have to get aftermarket shocks and struts to go with the lowering springs? or can I stick with OEM ones? i was told i had to b.c the H&R springs would wear out the OE shocks and struts.......
oh and i was thinking of Ebiach shocks and struts w/ H&R lowering springs...
Rich_Guy is offline   Reply With Quote
Old 12-25-2009, 02:27 AM   #2
upton7's Avatar
Re: suspension..
You don't have to because of the springs but it is better to because it is eaiser to do them at the same time since your already in there. (even if a shop or dealership is doing it) And you MUST get caster camber plates. Maximum motorsports will be your safest bet.
Old 12-25-2009, 09:44 AM   #3
Region: Iowa
Re: suspension..
Agree. The CC plates/springs/struts all work together as 1 unit.
You can run your stock shocks/struts, but you have to unhook the struts to replace the springs so it is easy to replace them when you replace the springs.
CC plates will allow you to align the car back to spec (you may not be able to when the car is lowered) plus it will allow you greater adjustment if you want to go road racing/autocrossing. And, since you have the struts off the car (to replace the springs), it is a good time to install the CC plates.
Tokico makes a nice adj. shock/strut kit as well. It is their D-spec kit.
I run the Tokico D-spec/Eibach/MM CC-plates on my 08 car.
NQSperformance
Vendor for:
American Muscle - Maximum Motorsports - Stack Racing - Koni - Tokico - H&R - Eibach - Hawk - Powerslot
John@NQS is offline   Reply With Quote
Old 12-25-2009, 09:12 PM   #4
DarkShadows's Avatar
Re: suspension..
I'd tell you my setup, but it's a bit on the stiff side.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Suspension 04_GT 1996-2004 Mustang GT 10 07-23-2010 07:01 PM
66 Suspension? SC_STEEDA Classic Mustangs 2 08-08-2009 08:24 PM
suspension bobbyoooo 1996-2004 Mustang GT 7 07-03-2009 03:08 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension help tim11 Pre-2005 V6 Mustang 5 10-23-2005 02:53 PM
03:30 PM
