Originally Posted by StangGt804 added some springs n shocks/struts!!! list coming together! check it out!
Kenne Belle 1.7 Kit with accessories
302 Stroker Shortblock
VT Blower Cams
Stage 2 ½ Heads
Bassani Headers
Aluminum Driveshaft
Steeda Upper/Lower Control Arms
Steeda Subframe Connectors
Blistein Shocks & Struts
Eibach Pro Springs Kit
BFG KDW2's - 295/35/18 & 265/35/18
DD Black FR550 18x9/18x10 inch
looks good? |
you can get the stuff i put in bold from maximum motorsports. i've heard more positive things about their suspension products than any other manufacturer. might be something you want to consider. their link is
www.maximummotorsports.com
frpp upper control arms are the most efficient/least problematic on the market. even over steeda and mm...
get coilover up front, your handling will improve greatly
subframe connectors and a panhard bar are definitely things you ought to add to your list. aftermartket k member and front control arms if you really wanna get hardcore and save some weight off the front (again, i recommend
www.maximummotorsports.com)
that's all my parts advice, but i'm wondering, do you have like $6-8k to blow right now, or is this a spread out plan of action?
