new parts same problem. - Mustang Evolution
Old 12-29-2009, 11:19 PM   #1
ok 1998 gt and recently coolant was coming out of the cap at higher rpm's so i replaced the cap and it still flying out of the cap. What is the problem? its 2 degrees out side and i got no heat or money for coolant every week.
help Edd
eddie1 is offline   Reply With Quote
Old 12-30-2009, 12:27 AM   #2
02MGGT's Avatar
Re: new parts same problem.
There is a good chance that the degas bottle is crap.
I be Trollin' Mon
02MGGT is offline   Reply With Quote
Old 12-30-2009, 09:27 AM   #3
no idea what that is....were is it at and im guessing it lets off pressure in the system
Old 12-30-2009, 02:52 PM   #4
02MGGT's Avatar
I be Trollin' Mon
Old 12-31-2009, 10:39 PM   #5
ok so the tank thing could be bad and causing the coolant to keep coming out the cap?
what causes these to go bad is it normal?
Old 01-01-2010, 04:51 PM   #6
MonteCitan's Avatar
How's the temperature of the car? does it run hot/cold?
Usually the higher RPM of the water pump isn't enough to cause excessive pressure/overflow/coolant spewing from cap..
A bad cap or leaking bottle would typically leak any time the coolant is warm/under pressure
Does the bottle look cracked where the coolant cap screws on?
Could be a pressure leak elsewhere in the system, or an issue such as head gasket..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-01-2010, 05:24 PM   #7
67mustang97's Avatar
Region: Vermont
How old are your radiator hoses? Are they collapsing? Is it the original thermostat?
Old 01-03-2010, 01:28 PM   #8
new thermastat came with the intake(one with aluminum coolant lines)........i did find out it leaks no matter what rpm.........and its only coming out through the cap/tank, no other places.......you said something about the hoses? do you mean like there blocking the coolant its self? if so i may be wrong but but my heat works on and off now that theres basicly no coolant in the tank i don't know if that means anything.
Old 01-04-2010, 09:30 PM   #9
do a coolant pressure test.
iamdat is offline   Reply With Quote
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
Problem cntry_maverick General Mustang Discussion 11 01-27-2009 09:03 PM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
12:31 PM
