Vortech S trim - Mustang Evolution
Old 12-15-2005, 12:01 PM   #1
Vortech S trim
Does anybody know how much boost you can get out of a s trim? (max)
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 12-15-2005, 12:02 PM   #2
Re: Vortech S trim
which is better the S trim or the A trim for boost?
Old 12-15-2005, 12:07 PM   #3
Re: Vortech S trim
are you joking? I havnt even seen an A trim for the newer mustangs. Only the five oh's
Old 12-15-2005, 12:09 PM   #4
Re: Vortech S trim
I know the A trims & paxton novi 1000's are 5-6 psi & strims are 8-10 but with a pulley change all that can change.
Old 12-15-2005, 09:09 PM   #5
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
Re: Vortech S trim
I've seen the number 15 tossed around....
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 12-15-2005, 10:08 PM   #6
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Vortech S trim
Haven't realy looked into those much but I also was thinking 15...
DarkShadow is offline   Reply With Quote
Old 12-16-2005, 12:18 PM   #7
Re: Vortech S trim
according to vortech the maximium the s trims should take is 20 at most. FYI: the procharger equivilant to that head unit takes up to 30 psi.
bigpomps is offline   Reply With Quote
Old 12-16-2005, 01:20 PM   #8
Re: Vortech S trim
I highly doubt a P1SC is going to hit 30 psi. heck, 15 psi is probably the max for that as well.
-Adolf Hitler, 1935
Old 12-16-2005, 09:22 PM   #9
Send a message via AIM to white95v6
Re: Vortech S trim
well i have seen a S-trim do 17psi. and i have seen a P1sc do 19psi. you all gotta remember boost is a measurement of restriction. soo it all depends on the engine.
also both examples above where on built 4.6L DOHC engines. soo you know those things move alot of Air.
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 01-19-2006, 07:27 AM   #10
Re: Vortech S trim
You should be able to make at least 20 psi with an s-trim. When I was running an s-trim with an 8" crank and 3.33 on the blower I was seeing 18 psi.
Eric
1990 Mustang GT
9.75 @137.13
Check out this forum for AOD's: Click Click Racing Forums
My Homepage
RdRunnr is offline   Reply With Quote
Old 01-19-2006, 07:58 AM   #11
xtremejc's Avatar
Re: Vortech S trim
I am currently running 18 psi on my S-trim and it is almost maxed out so I can easily say that the S-trim will support 19 psi or so... I have seen the P1SC tap out exactly at around the same psi as they are very similar blowers...
JC
1997 Rio Red TT Cobra
2003 Mineral Gray Whipple Powered Cobra
2006 Redfire A/T Mustang GT
xtremejc is offline   Reply With Quote
Old 01-19-2006, 09:21 AM   #12
Re: Vortech S trim
Sweet! I guess there is no need to get a T trim then. I wonder why on project ice box, they switched to a t trim? I am sure i will be fine with a s trim. Thanks for the help team.
Old 01-19-2006, 10:21 AM   #13
xtremejc's Avatar
Talking Re: Vortech S trim
The T trim will support up to 26 or so PSI and will take a full power cobra with a built motor well into the 9's in the 1/4 mile...
If you are interested in buying a customized S-Trim with race bypass, powerpipe, and 8 rib drive setup please PM me and I will give you a deal that would be hard to resist. Here is a pic of my setup:
JC
Old 01-19-2006, 10:33 AM   #14
Re: Vortech S trim
You shouldn't really look at "max boost". You should be more concerned about blower efficiency. This is why the yswitched. A t-trim is much more effecient and will make better power across the power band. The boost comes on sooner with a t and is more consistent at lower rpm's where as an s -trim would have to be spun like crazy and would make the same low/mid range power. 18psi on an s-trim and 18 psi on a ysi or t-trim are not necessarly the same.
Eric
1990 Mustang GT
9.75 @137.13
My Homepage
Old 01-19-2006, 02:17 PM   #15
Re: Vortech S trim
where do the eatons max out at, i havent seen any posts about them above 15psi.
Old 01-19-2006, 02:33 PM   #16
xtremejc's Avatar
Thumbs up Re: Vortech S trim
They begin to get heat soaked at boost pressures past 14 psi but having them ported increases the efficiency enough to allow them to be boosted upwards of 18 psi or so...
JC
Old 01-19-2006, 05:14 PM   #17
Re: Vortech S trim
I am so jealous of you texans. lol I dont think I am gonna pass smog here in Cali with a s-trim so I might as well go with a t-trim.
Old 01-19-2006, 05:18 PM   #18
Re: Vortech S trim
what would the price be for that setup you offer? do you own a shop or is this off your own personal vehicle.
Old 01-19-2006, 07:40 PM   #19
xtremejc's Avatar
I do not own a shop but I do all my own work. The blower is mine and it's about to be removed in favor of a custom GT4280 turbo setup I'm currently working on.
Please PM me for a price on the blower...
JC
Old 04-27-2006, 08:19 PM   #20
Re: Vortech S trim
I went with the T trim on my Steeda from the S trim huge improvement I dropped from 17-18 to 12-14. I also noticed an improvement in power because theS/C is not working as hard. It is alot louder than the S, but I like it.
DanzCherry68 is offline   Reply With Quote
Old 05-23-2006, 05:12 PM   #21
Re: Vortech S trim
I have a p-1sc on my cobra now @18psi.
snake99bite is offline   Reply With Quote
Old 08-06-2006, 12:25 AM   #22
Region: Montana
Re: Vortech S trim
highest i've seen is 17 on a car with stock manifolds and o/r x and catback.. They sound like they are going to explode when you spin them that fast.. I have a video of it on my canon.
95 Crystal White Cobra #702 of 4007
Polished Vortech S-Trim @ 12psi
18X9 FR500s
MANY INTERIOR MODS...
Coming soon....Dart 427 with a T-76!!
Blwnbyu is offline   Reply With Quote
Old 08-06-2006, 12:27 AM   #23
Region: Montana
Re: Vortech S trim
God I love turbos.. Once you've had one, you will never go back to a centrifigul again..the only time I could see not wanting a turbo more is on a fun and heavy "street" car which you wanted Instant big block torque, in which case it would have a 2.6 or 2.8L Kenne bell.
18X9 FR500s
Quarter window trim MetallicMist Mustang Audio & Video 16 10-24-2009 09:49 PM
F/S V-1 S-trim Mike Daniels Mustang Parts for Sale and Wanted 3 02-20-2007 10:58 AM
F/S V-1 S-trim Mike Daniels Mustang Parts for Sale and Wanted 1 02-07-2007 12:37 PM
S-trim vortech 2quick Mustang Parts for Sale and Wanted 2 11-13-2006 02:52 PM
Gear Shift Trim Ibanezplayer272 Mustang Audio & Video 2 08-02-2004 09:10 PM
08:11 PM
