Weird Grinding Sound? - Mustang Evolution
Old 01-14-2010, 08:47 AM   #1
Gt.Vert's Avatar
Unhappy Weird Grinding Sound?
ok so i have my car parked in a garage and in the morning when i take it ...im in first than when i goto second it makes this sound like its grinding or something and it dosent let me go in second so i pull back to neutral and go back again and it does it fine after the first time?????
dunno wtf is going on but sounds like its killing my car...any ideas and cost of fixing that...ohh and i do have MGW short shifter...
Gt.Vert is offline   Reply With Quote
Old 01-14-2010, 09:09 AM   #2
Re: Weird Grinding Sound?
second gear synchronizer is going bad, first signs are cold weather... and heck some manual transmissions do this with low miles so dont lose sleep over it.
You should just realize its going to do it and put it in neutral for a sec and let off the clutch then push the clutch back in and slide it into second gear after that until it warms up. My car is hard to get into second when its cold as well. You can change the fluid (supposed to do that regularly its not a lifetime fluid) in the transmission~
do you speed shift hard into second? One other thing you can check is your clutch adjustment. If you have to have your foot actually pushing on the floor pushing in the clutch petal to shift then you have to much slack and not enough engagement (not pulling the cable enough with the clutch petal) and you need to adjust this. Basically you might be shifting the car with only X amount of clutch pushed in vs what you should have~ cold weather just accents such issues and makes them more noticeable. When I first purchased my car it was a pain how hard it was to shift, a clutch cable adjustment made it 10000x better.
You can adjust it by crawling down under the dash (facing down), looking above the accel petal and taking one hand and hold it on the clutch quadrant and the other and push the clutch petal down ease the clutch petal up and hold tension on the quadrant against its movement its trying to do. Let it slowly out and you will heard a "click" this is it taking up slack. Take up slack until the clutch petal is FIRM at the top (no flop) and test drive. Make sure you have a half inch of travel of the clutch petal as you push it in before the clutch slips (go 55mph or 45mph hold the gas constant with your foot and ease in on the clutch when the rpms jump thats slipping.)
If you have an after market quadrant you can use a firewall adjuster to do the something.
Old 01-14-2010, 01:31 PM   #3
Gt.Vert's Avatar
thks alot man ..gonna try that this weekend...and i think it is due to cold weather ..it started happpeing last couple of days i thnk..so ill c what happens
Weird sound when turning? SC_STEEDA Pre-2005 V6 Mustang 4 11-16-2009 06:36 PM
grinding sound elystarz New Member Introductions & Greetings 1 08-15-2009 06:57 PM
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
Ever since I bought my car I have had this weird sound under the hood! 03redfire cobra The Bar 31 07-11-2004 07:55 PM
grinding sound, stiff breaks, and loos of power wile driving blk2kconvstang Pre-2005 V6 Mustang 4 04-05-2004 07:20 AM
04:55 PM
