03' motor and tranny swap with 98' GT PLEASE HELP!!! - Mustang Evolution
Old 01-16-2010, 07:18 AM   #1
Exclamation 03' motor and tranny swap with 98' GT PLEASE HELP!!!
ok currently i have 98GT motor and tranny (auto) and im in the middle of swapping in a 2003 motor and tranny (auto). i did my research for what i need on the motor swap. I plan on using my 98' wiring harness and 98' computer. now my problem is.... will my 98' harness and computer work with the 03' tranny. the reason i ask is because the 03' tranny is control thru the computer for the speedo and my 98' i have a small black gear inside the tailshaft of the tranny to adjust my speedo correctly because i have 3.73 gears. i looked inside the side of the 03' tranny and dont see a gear on the shaft to grab onto my speedo gear to control the speedo. will the speedo work correctly?? will the tranny even shift at all because of the difference?? i really need all the help i can $$ is tight and this my daily driver. please all advice would be greatly appricated
BAttitude7689 is offline   Reply With Quote
Old 01-16-2010, 11:40 AM   #2
big show 98's Avatar
Re: 03' motor and tranny swap with 98' GT PLEASE HELP!!!
To make life easy & cheap stay with the 98 trans. Both are 4r70w's. Also I installed a 01 gt engine into a 96gt if you have any engine swap questions.
big show 98 is offline   Reply With Quote
Old 01-16-2010, 10:38 PM   #3
Zebs5408's Avatar
google google google man! i know how it is to have a daily driver down, both of mine our lol, im gonna look around and see what i can find!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-17-2010, 02:32 AM   #4
02MGGT's Avatar
Cobra's never came with the 4r70w. 03/04 came with the T-56.
I be Trollin' Mon
02MGGT is offline   Reply With Quote
Old 01-17-2010, 02:39 AM   #5
03 GT motor & trans I assume the OP has.
Old 01-17-2010, 02:56 AM   #6
02MGGT's Avatar
doh, reading comp>me. I'm so use to people saying 03 (Cobra)
I be Trollin' Mon
Old 01-17-2010, 07:08 AM   #7
Wouldn't the OP be better off using the '03 computer and harness? What are the differences between the '98 and '03 engines? Are they both 2-valve? 4V? If different, won't they have different sensors that the '98 computer won't be programmed to monitor? There is a difference in HP and torque between the two model years; correct? Seems like the '98 computer and software would "detune" the newer engine. I'm just asking because I don't know.
MetallicMist is offline   Reply With Quote
Old 01-17-2010, 04:58 PM   #8
You use the 98gt set up, injectors,harness,coilpacks,etc. The 98 computer will run the 03 engine just fine. (referring to the 2V). A hand held tuner will catch the slack. The 98 is programed for a 225hp engine.The belt configuration is different on the 03 but all of the accessory's are located in the same location. I ran a 01 engine in a 96gt with the 96 computer & it ran & performed perfectly.
Old 01-17-2010, 06:31 PM   #9
Cool. I learned something. Even us old farts can still learn a few things...
Old 01-17-2010, 06:55 PM   #10
90% of my knowledge came from old farts!!
Old 01-20-2010, 06:33 PM   #11
birdman941's Avatar
No messing with the electrical side of the fuel system using the 98 PCM either.
100% hand built 2004 Cobra (body in white)
Boss 330 built 5.4 32V NA
404/387
birdman941 is offline   Reply With Quote
motor swap v6 to v8 El Jefe Pre-2005 V6 Mustang 5 12-23-2009 09:06 AM
98 mustang engin/tranny swap Mustangbobby General Mustang Discussion 0 04-17-2008 07:34 PM
98 Engine/tranny swap Mustangbobby Pre-2005 V6 Mustang 0 04-17-2008 06:51 PM
Tranny Swap 1234 1996-2004 Mustang GT 20 03-07-2007 08:12 PM
Motor Swap coolstang 1996-2004 Mustang GT 1 04-20-2005 09:04 PM
07:46 PM
