ignition switch - Mustang Evolution
Old 01-16-2010, 02:22 PM   #1
upton7's Avatar
ignition switch
is there a certain wire i can cut and put a toggle switch or button on and hide it under the dash so only i know how to start the car
Old 01-16-2010, 10:08 PM   #2
Zebs5408's Avatar
Re: ignition switch
im sure but i would leave it to were your key still has to be in for safety purposes LOL, but yea bor im sure! google it and it will tell you step by step.
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-17-2010, 10:46 AM   #3
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: ignition switch
if you take apart your steering column and get to the ignition swith for key, use a test light to find the one that lights up when key turned to on position, then splice a wsitch into that wire, then you will still have to have key in ignition and the switch must be activate to complete circuit
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 01-17-2010, 02:35 PM   #4
upton7's Avatar
Re: ignition switch
any chance i can get to that wire from under the dash?
Old 01-17-2010, 06:09 PM   #5
Re: ignition switch
Someone previously did it to the 94 that I bought my wife. Unless the toggle is pushed to on, the car won't start. As soon as I can crawl under the dash and see, I will post what I find.
winterwolf is offline   Reply With Quote
Old 01-17-2010, 07:14 PM   #6
OsirisGuy's Avatar
Re: ignition switch
It will probably be easier for you to remove the steering column shroud then dig around under the dash on your back.
You could interrupt the Ignition or Starter wire but make sure the switch you pick up can carry the amperage needed.
Just know that if a thief wants your car bad enough, he'll find a way to take it.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 01-17-2010, 10:51 PM   #7
upton7's Avatar
Re: ignition switch
I'm fully aware. Beleive it or not this is to keep my family from driving it when they get in it they steal my cigarettes and I figure if they find out that i've done something so they can't start it they won't bother going into it anymore. (they only do that when they are in it they don't just go into it just for that reason)
Ignition System blue-saleen Pre-2005 V6 Mustang 6 12-21-2009 03:52 PM
MSD ignition help blown347ranger 1979-1995 Mustang GT 12 05-30-2007 04:09 PM
Need help with some possible Ignition upgrades Kiljosh Pre-2005 V6 Mustang 10 11-30-2005 11:26 PM
Better ignition for 98.... TheSarge Pre-2005 V6 Mustang 2 09-15-2003 09:43 PM
03:08 PM
