5.4 32V NA Project done! Dyno, vids, pics - Mustang Evolution
Old 01-18-2010, 06:22 PM   #1
birdman941's Avatar
Bought the body in white in 2005.
Now powered by an Al Papitto built 11:1 5.4 32V motor
Motor uses Aussie Boss intake, Boss 330 cams,
Custom LT's, 2000 "R" spec T56, 04 Cobra IRS w/STEEDA upgrades,
but mostly OE Ford parts.
99% 04 Mach 1 wiring and PCM, 1% Terminator wiring (Decklid)
Yes, I built the entire car, and used it to develop the swap kit.
Started here Feb. 2005:
Crate motor for testing with Aussie Boss lower intake:
100% hand built 2004 Cobra (body in white)
Boss 330 built 5.4 32V NA
404/387
birdman941 is offline   Reply With Quote
Old 01-18-2010, 06:26 PM   #2
birdman941's Avatar
Re: 5.4 32V NA Project done! Dyno, vids, pics
Early motor test fit:
Early side shot:
Shot of prototype sheetmetal upper:
404/387
Old 01-18-2010, 06:32 PM   #3
birdman941's Avatar
Early startup:
Final design upper intake:
404/387
Old 01-18-2010, 06:33 PM   #4
birdman941's Avatar
Back from paint:
404/387
Old 01-18-2010, 06:35 PM   #5
birdman941's Avatar
Ready to reassemble:
Rear painted and assembled:
Body assembled:
404/387
Old 01-18-2010, 06:38 PM   #6
birdman941's Avatar
Interior prior to motor install:
Engine bay ready for an Al Papitto built bullet:
Motor installed:
Side shot:
404/387
Old 01-18-2010, 06:40 PM   #7
birdman941's Avatar
Idling with Crower stage 3 NA cams (Since replaced with Boss330 cams)
Idling with Boss 330 cams:
404/387
Old 01-18-2010, 06:43 PM   #8
birdman941's Avatar
Sitting on the dyno at BrooksSpeed in Ga.:
Running for numbers:
Results: 300 min Lb./ft. from 2300 RPM to 7k, max torque 387
(One run was 402/398)
404/387
Old 01-18-2010, 06:44 PM   #9
Zebs5408's Avatar
:worship: ooohhhh how i invy theeee
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-18-2010, 06:46 PM   #10
birdman941's Avatar
Forgot, pics before disassembly and paint:
404/387
Old 01-18-2010, 06:51 PM   #11
birdman941's Avatar
Thanks, it is an absolute blast to drive.
I would not change a thing.
404/387
Old 01-18-2010, 07:06 PM   #12
AMAZING!!! I couldn't imagine the amount of man hours put into this. I tip my hat sir.
I really want to do something like this in the future as a side project, it'd be badass!!!...great work.
Old 01-18-2010, 07:11 PM   #13
I might have missed it posted in between the pics, but when did you finish her?
Old 01-18-2010, 07:12 PM   #14
birdman941's Avatar
Many long nights in the garage (NO lift or compressor by the way),
a few skipped meals, barrels of Mt. Dew....................
There are a few more around here with this setup.
My buddy's 98 Cobra with a VERY mild 5.4 put 345 Tq. to the wheels
on a fresh motor (I built it), and it has gained some since.
It's forged crank, rods and pistons, stock unported 01 heads,
shorties, O/R H pipe, and FGT cams and 4.10 gears.
All fit under the stock Cobra hood.
I do have a couple pics of that one.
404/387
Old 01-18-2010, 07:15 PM   #15
birdman941's Avatar
Final finish with the Boss 330 cams was late November when
I was in Texas for a bit.
I originally wanted his design cams,
but they were in the pipeline when Crane shut down,
so I went with Crower Stage 3 NA cams.
It busted a sec. timing chain, so I switched to Al's cams at that time.
Not sure why a brand new chain went, but it did.
404/387
Old 01-18-2010, 07:20 PM   #16
birdman941's Avatar
My buddy's 98 Cobra in process about March 09:
Motor done:
Crummy quality video: (camera has been replaced since)
Crummy vid #2
404/387
Old 01-18-2010, 07:32 PM   #17
If you don't mind me asking, what's the cam specs on yours.
Old 01-18-2010, 07:35 PM   #18
birdman941's Avatar
I am not sure exactly, as they are Boss330 racing proprietary grinds.
I do know they are around 13mm lift,
with a bit more duration and overlap
than the Crower Stage 3 NA cams.
Al spent a lot of time deciding the package, from the piston design,
which are custom CP slugs, the head porting and the cams.
This was the first motor he built with my Aussie Boss setup,
which has 10" runners.
There are a few more in the works,
with one being a twin and going into a Mach 1.
It makes a crapload of torque, and pulls HARD all the way up.
And I do mean HARD.
404/387
Old 01-18-2010, 07:38 PM   #19
Bad *** dude, I don't know if you remember me but I bought your old tires off of ModularFords.com, but I have been following your progress. Great work, definitely effin' sweet! Since my 95 is nearing completion, I'll hopefully start tearing down my navi motor.
96 GT- Who knows what's in it.
Old 01-18-2010, 07:40 PM   #20
Cool, just wondering...they have a nice lopey idle...makes me wish all newer v8 mustangs came with the 5.4L and those cams, lol.
Ode to the good ol' days
Old 01-18-2010, 07:41 PM   #21
birdman941's Avatar
Cool and thanks!
Those tires had very few miles on them.
Those were on this car originally until Dario at STEEDA
gave me a killer deal on a set of 275/40/18 Nittos.
404/387
Old 01-18-2010, 07:46 PM   #22
birdman941's Avatar
I didn't mean to have a short reply, I edited it.
Must have hit the wrong key on the above camshaft post.
(My bad)
The idle sounds rough, but under the hood it's silky smooth.
As soon as you hit the throttle, it is exceptionally smooth,
and the torque is unreal, as you might guess looking at the sheet.
The car has IRS w/3.55 gears and (repeating myself again)
It pulls so hard, feels like a roller coaster or a freight train.
Al knows his stuff.
I told him I wanted high torque, and around 400/400.
Once the motor is broken in and it gets tweaked,
it should be well over 400 on both counts.
404/387
Old 01-18-2010, 07:57 PM   #23
Cool and thanks!
Yea those tires looked brand new! It was definitely a good deal! Are you still making swap kits? I saw a post when you said you only had one left, didn't know if you were still making them.
Old 01-18-2010, 08:00 PM   #24
birdman941's Avatar
Yes, that should be handled via PM's, as I am not a vendor here.
I do know of a Fox chassis owner doing this setup but with twin turbos.
Can you imagine the torque?
That one is going to be a front inlet TB.
404/387
Old 01-18-2010, 08:08 PM   #25
That's gonna be one nasty fox! Can u pm me when you get a chance?
Old 01-18-2010, 08:24 PM   #26
hottcobra's Avatar
very sweet ride
I like the pre paint look
Old 01-18-2010, 08:29 PM   #27
birdman941's Avatar
Originally Posted by hottcobra View Post
very sweet ride
Yeah, thanks, here it is in motion.
No windshield or back glass.
Stock Navi long block, Aussie intake, LT's.
404/387
Old 01-18-2010, 10:41 PM   #28
(My bad)
Al knows his stuff.
That's crazy man...I just love that it's a nice, big naturally aspirated engine...takes badassness to an all new level. I could imagine anything taller than 3.55's would make 1st pretty much useless
Old 01-18-2010, 10:50 PM   #29
Zebs5408's Avatar
serously bro u have a gift and you most def have my respect..i got ur back in here anytime man! i would have to wear a condemn driving this thing cause i would nut everywhere :pickle:
Old 01-19-2010, 06:06 AM   #30
birdman941's Avatar
Thanks guys.
Currently waiting on FDOT paperwork to have it inspected,
have a VIN assigned, and then be able to drive the car.
Hoping all goes well with that.
I do plan on taking it to the STEEDA Stampede later this year,
and joining up with a couple/few more 5.4 NA cars,
maybe even one or two from Vero Beach, Fl.
No disrespect to FI folks, but after seeing a few hundred blower cars,
NA is a nice change of pace at shows.
404/387
Old 01-19-2010, 06:13 AM   #31
Zebs5408's Avatar
this is true force iduction is the HOT thing right now! even on 6's LOL, good luck man ill def be keep up with you bro
Old 01-19-2010, 08:17 AM   #32
birdman941's Avatar
I have always been an NA guy, small car with a big motor.
LONG ago, I put a 351C 4V in a Mustang II,
drove it for 10 years before I sold it.
404/387
Dyno vids and pics w/ new exhaust bandit Pre-2005 V6 Mustang 31 06-07-2008 08:37 AM
Pics and Vids of my M1 Garand Seph Pictures and Videos 24 05-03-2007 03:00 AM
Took the M1 down to the range - Vids n Pics - Seph Pictures and Videos 6 04-27-2007 09:55 AM
808whp evo -- Dyno vids Monkey The Bar 13 11-05-2005 06:15 AM
Did some offroading and took some pics/vids sonic04edge Pictures and Videos 6 11-25-2004 07:17 PM
07:58 PM
