Needs some assistance! - Mustang Evolution
Old 01-27-2006, 07:07 PM   #1
Region: Hawaii
Exclamation Needs some assistance!
I know this has been beat to death, but i have to ask Anyway What will be needed to swap a 4.6 into a v6 shell. Before you start in on me as you can see by my title i have a wrecked 2001 gt(BTW insurance wouldn't cover it, long story ). I am aquiring a v6 probably a 99. what exactly has to be swapped over? I live on a Air force base so i have access to lifts, engine stands etc. etc.. Also how long do you think this would take? I have done engine swaps before(FWD cars only) and i am mechanically inclined. My friend has done full restorations on cars and he will be helping me. Any input geatly appreciated. Thanks.
wrecked2001 is offline   Reply With Quote
Old 01-27-2006, 09:30 PM   #2
Re: Needs some assistance!
You will need:
engine
transmission
driveshaft
rear end
suspension
wiring
gauge panel
computer
pretty much anything you can pull off your car and put on the v6 shell will do you good.
Old 01-28-2006, 12:36 AM   #3
Region: Hawaii
What about the radiator, mines is FUBAR. Also is it easier to remove the engine from the bottom of from the top?
Old 01-28-2006, 10:46 AM   #4
Yeh, you will need a radiator also...pretty much, anything that supports the engine in any way will need to be changed.
Old 01-28-2006, 11:08 AM   #5
its alot more work that you are thinking and it will cost alot more as well
Old 01-28-2006, 10:26 PM   #6
Region: Hawaii
Why? The only thing damaged is the front end. The engine through back end is all good. Me and about 3 other guys are going to tackle it. I am doing all the work myself so no labor cost. The car is completely intact, heck it still starts and drives, so what am i missing as far as cost?
Old 01-28-2006, 10:44 PM   #7
Why not just swap over the front clip from the v6 and get ahold of another radiator?
Old 01-28-2006, 10:51 PM   #8
Region: Hawaii
Because i want v8, just a personal preference. Plus i got about a Month of leave to burn anyway.
Old 01-29-2006, 12:51 AM   #9
I know you want the V8, I'm saying replace all the stuff that's messed up on your GT with parts from the V6...unless the frame is bent or something like that. But, if you're buying a V6 to swap to, why not just swap parts from it, then part out the rest of the car.
Old 01-29-2006, 01:14 AM   #10
Region: Hawaii
I meant to edit that, didn't get it until later, anyway yeah the frame has shifted. It would need to be aligned(hit something pretty solid) anyway that is why i want to do the swap.
Old 01-29-2006, 12:28 PM   #11
O ok, well about all I can say is take everything from the GT you can salvage and put it on the V6 chassis, like as far as the drivetrain, you will pretty much need to transfer everything over.
Old 01-31-2006, 12:32 PM   #12
Rick0636's Avatar
I don't think that the wiring harness has been mentioned, I am sure you will need that too. I dont' envy you the job at all, but try and enjoy it! As you can see, My GT hit something pretty solid too, I recommend that any Mustang convertables get heavy duty (not light bar) Roll bars installed for their health, my back will never be the same.
ID:	12094   Click image for larger version
Old 01-31-2006, 10:29 PM   #13
Region: Hawaii
Yeah I am a Aircraft Electrician in the Air Force, plus I worked at Circuit City some 6 odd years in the stereo installation department, so wiring is probably the easy part for me. Thanx for all the info, I will let you know when I get started a post some pics.
Old 02-01-2006, 04:21 PM   #14
Sounds good man and do keep us posted.
Old 02-02-2006, 11:21 AM   #15
Region: Hawaii
Can you get a factory service manual from Ford? I need it for torque values and procedures and info.
Old 02-02-2006, 05:37 PM   #16
Yeh, you can order a new manual from ford. I'd recommend getting a hayne's manual or the equivalent however, better detailed and more information for cheaper.
Old 02-02-2006, 06:18 PM   #17
Region: Hawaii
Thanx.
Old 02-03-2006, 10:10 AM   #18
Rick0636's Avatar
I was in the Air Force for a little over 3 years in the early 70s, got out on a disablity, sort of a nervous breakdown thing. I am 100% service connected now, have been for about 10 years. I was a supply person, warehouse, after hours support, repairable parts monitor, WRSK kits, etc.
Old 02-07-2006, 07:34 PM   #19
Region: Hawaii
***Update*** I am going to pick up the project car today. It's a 99 v6 5-speed with just under 53000 miles. Blue in color real good shape. I will post pics later.
Old 02-07-2006, 07:48 PM   #20
wouldn't happen to be atlantic blue would it?
Old 02-07-2006, 11:41 PM   #21
Region: Hawaii
Yes sir Atlantic blue with low miles(benefits of living in hawaii). Good shape only minor scratches and dings, nothing a good detail can't take care of. Got for only $5400. I will post pics soon.
Old 02-07-2006, 11:54 PM   #22
Atlantic blue is fairly rare...I'd keep it that color if it was me.
Old 02-09-2006, 12:13 AM   #23
Region: Hawaii
Three things became evident when I swapped the rims on the cars.
1st ABS. GT has V6 dosen't, Is the ABS controlled by the engine computer? I know it sounds weird but, on most cars ABS controls the traction control system that's why I ask. Will I get a ABS light when I put the GT computer into the V6 body with no ABS sensors? Also will the ABS hydrobooster work with non-ABS system?
2nd Is the V6 and GT steering rack the same?
3rd Is the V6 and GT A/C compressor the same?( I live in Hawaii, it is pretty much a necessity)
Old 02-09-2006, 02:58 AM   #24
Region: Hawaii
Here are the pics
Project carClick image for larger version
ID:	12158Click image for larger version
Donor CarClick image for larger version
ID:	12160Click image for larger version
I swapped the rims already in these pic's. Can't wait to get started.
Need Assistance w/S197 Front Spoiler Identification 3ricchu Mustang Audio & Video 6 07-18-2008 06:54 AM
Assistance with N2O and launching DarkShadow 1996-2004 Mustang GT 20 04-20-2007 08:51 PM
Photoshop assistance required wiarumas Mustang Wheels & Tires 12 04-03-2005 09:16 PM
A little assistance please... KrazyPony The Bar 13 04-07-2004 04:52 PM
Saleen Bumpers Installation Assistance or Guidance KrazyPony Mustang Audio & Video 5 09-23-2003 12:08 PM
07:53 PM
