any suggestions looking for more upgrades - Mustang Evolution
Old 01-28-2010, 11:28 PM   #1
So i have a 2000 GT, i changed the gears to 3.73, did the exhaust flow masters, got the cold air intake, i even got the racing clutch. i was wondering what i should do next. i have been thinking about headers or maybe a chip or just a tune. any suggestions on what i should do???
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
and a 18 year old adrenaline junkie :burnout:
jkaminski24 is offline   Reply With Quote
Old 01-28-2010, 11:29 PM   #2
Re: any suggestions looking for more upgrades
What are your goals for the car? Have you done anything suspension-wise to help put the power to the ground? What about added stopping power?
Old 01-28-2010, 11:37 PM   #3
no i havent done anything with the suspension or stopping power everything else is pretty much stock. what would you recommend?
I really just want a BADASS mustang, something that sounds good and runs even better. Something to kinda shut my dad and his vette up i dont have to beat it i just want him to be like Damn lol
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 01-29-2010, 07:28 AM   #4
well you can go for more power you can do looks or looks and suspension
If you want power a new upper intake, remove cats, adjust timing, tune (must be a good dyno tune NOT a mail order tune, you can buy the tuner in the mail but dont use their default "performance" tune lol. Replace it with a tune using a dyno with a good tuner and you sould see much better gains)
For looks/suspension lower it, wheels tires, wheel spacers maybe those make a huge difference. Springs run from 150-250 generally and you will need caster/camber plates for a good drop so you can align it and the tires wont wear funny on the front.
Old 01-29-2010, 08:36 PM   #5
Yah you can make a white mustang looks really good. Rims/tires, a drop, some accents based on your wheel preference, etc...what SpectorV said, lol.
There are plenty of things you can do to build on top of the upgrades you've done already. The intake and tune along with some supporting suspension mods should wake the car up pretty good and surprise your old man.
A power adder and some internal work will blow him away.
Old 01-29-2010, 08:39 PM   #6
Oh and longtube headers, an offroad h-pipe, and some borlas or magnapacks will put that vette to shame in the sound department IMO.
Old 02-03-2010, 12:52 PM   #7
what would be a good tuner to purchase and a dyno how do i go about getting one? price range?
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 02-03-2010, 01:55 PM   #8
upton7's Avatar
Call a good dyno shop ask them what tuner they work with and get that one like say sct. Or you can save 380 bucks and have them flash it right into your ecu. The benefits of gettingthe tuner is reading and clearing trouble codes and you can reset the car to the stock factory tune.
Old 02-04-2010, 08:31 AM   #9
Send a message via AIM to tedness
your car is a 2000 gt? suspension is something i would recommend for sure. get some new shocks and struts: if you're on a budget tokico hp 'blues' are good, but if you have money then koni and bilstein are great. koni because of the range of adjustability, bilstein because they can be rebuilt fairly easily. a good set of springs too, something a bit stiffer than stock would make your car feel brand new.
but also in regards to a tune, a multi-position chip is good too. you can have the tunes loaded on from a shop and then switch back and forward between the stock and performance tunes with the turn of a knob.
tedness is offline   Reply With Quote
Old 02-04-2010, 08:43 AM   #10
Tuners local to you all use SCT almost exclusively. TPS will tune with the diablo handheld, but I don't believe they have the software to do it, they just use the device to tune with.
If you were to get an SCT tuner (XCal2, 3, etc), you could use TPS or StangHi to get your tunes for your car. You're looking at around $379 for the tuner, and then about $300-400 for a custom dyno tune.
New Upgrades Topxshelfxtre Pre-2005 V6 Mustang 43 04-22-2010 07:54 PM
Possible upgrades Nobletucky24 1979-1995 Mustang GT 10 01-13-2010 05:32 PM
Upgrades Chaotic_Theory Pre-2005 V6 Mustang 30 06-06-2008 08:01 PM
4.0 v6 hp upgrades how do they? rangex Pre-2005 V6 Mustang 7 03-12-2008 01:35 PM
10:20 PM
