Installed Tach 98 Gt - Mustang Evolution
Old 02-12-2006, 08:13 PM   #1
SilverStang96's Avatar
Send a message via AIM to SilverStang96
Alright, installed an autometer tach w/ shift light saturday... I need to know if anybody knows what color the tach wire is that i need to hook the GREEN wire into. I checked another forum and it said it was a TAN/YELLOW wire. I spliced into it and my tach didnt read an RPM... Everything else was hooked up right.. the only other problem im having is i hooked the white wire into my headlight switch (like it said) so that when i turned on my head lights or parkin lights the light on the tach would come on.... but it comes on whenever i turn the key over. Also, is the wire under the passenger kick panel???
Thanks..
SilverStang96 is offline   Reply With Quote
Old 02-12-2006, 08:50 PM   #2
Re: Installed Tach 98 Gt
i think you have to have a converter for some years, check and see if you need.
Old 02-13-2006, 06:15 AM   #3
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
It sounds like you spliced the 12V light wire to an ignition wire, which could be the reason that the light is coming on when you turn the key over... I remember in my 98 and even in the 90 I have now, the headlight/parking light wire is a light brown/tan...
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 02-13-2006, 07:33 AM   #4
my friends shift light on his tach comes on when he cranks the car.
Old 02-13-2006, 10:18 AM   #5
I liek gramer
WhiteStang99's Avatar
in my 99 the brown wire is the parking lights.
Old 02-13-2006, 10:31 AM   #6
My shift light blinks when i turn the key over too
Old 02-13-2006, 10:36 AM   #7
I thought that could be a possibility as well... I double checked my wires though. I have a water temp. and volt guages on my a-pillar... (autometer ultra-light) and the lights on those guages come on with my headlight/parking light, and they dim/brighten as well. So i just hooked the light wire into those wires.
Old 02-13-2006, 10:37 AM   #8
I asked around, but most said i didnt need one.
Old 02-13-2006, 10:38 AM   #9
Question Re: Installed Tach 98 Gt
So does anyone know what color the tach wire is for sure??? and is it under the passenger kick panel?
Old 02-13-2006, 12:15 PM   #10
Ohh you guys are talking about the shift light.. I thought you we're just talking about the light in the tach itself.. oops. :pnoid:
Old 02-13-2006, 12:36 PM   #11
ive always heard it was green/gray or something like that. I am not sure though.
Old 02-19-2006, 12:08 AM   #12
its behind ur instrument panel its the harness on the left the tach wire is brown/yellow it should be the same as mine i have a 97 mustang gt
gt 97 sohc is offline   Reply With Quote
« Predator | Mach 1 »
tach ? gearbanger67 Classic Mustangs 4 04-14-2007 07:06 PM
tach problem cash05_mustang Pre-2005 V6 Mustang 4 10-18-2006 06:16 PM
Tach not working... SilverStang96 Pre-2005 V6 Mustang 3 11-12-2004 11:34 AM
anyone need anything installed? Stylin97V6 Regional Mustang Discussion 4 12-19-2003 04:05 PM
11:53 AM
