HELP?! SWAP INFO?! - Mustang Evolution
Old 02-02-2010, 12:25 PM   #1
HELP?! SWAP INFO?!
I have been searching for a 4.6 SOHC for my 99 Mustang... I'm trying to find one locally. I've been getting tons of calls/emails from people who have 1994 4.6 SOHC engines. My question is what would I need to do to make this work. I have the originial 99 intake manifold with the fuel inj stuff on it.... One person told me he has the engine, trans, and comp... but I would like to keep the originial trans and comp... Is this possible, should I pick up one of these engines? WHAT OTHER PARTS WOULD HAVE TO BE SWAPPED ON THE 94 TO MAKE IT FIT IN THE 99... THANKS GUYS....
jbaker0217 is offline   Reply With Quote
Old 02-02-2010, 01:08 PM   #2
upton7's Avatar
Re: HELP?! SWAP INFO?!
if you stay with the trans youll need a different bell housing if you can find one.
And i have a 4.6 short block if you want it.
Old 02-02-2010, 01:56 PM   #3
From what car does the 4.6L come from? Ford's used the SOHC since 91 in lincoln town cars...they started using it in the mustang in 96...the 94/95 GT's had the pushrod 5.0's.
The 96/97 4.6L's were rated at 215hp 285tq, the 98's had 225hp 290tq, while the 99+ 4.6L's were rated at 260hp 302tq, so quite a bit of difference between the years. I'd look for a 99+ 4.6L for your 99. Anything else and your looking at lower starting numbers, plus a more difficult install.
Old 02-02-2010, 06:57 PM   #4
The 4.6 is from a 94 police car.
Old 02-03-2010, 10:16 AM   #5
upton7's Avatar
bellhousing ecu maybe motor mounts it really depends how much you get when you buy the engine if you get a complete engine and trans like you said you could it'd be alot easier.
Looking for info Firewolf 1979-1995 Mustang GT 7 10-13-2009 08:59 AM
i need a little info oaktonarcher General Car Discussion 10 08-10-2007 09:28 PM
need some info? ryanxup Pre-2005 V6 Mustang 2 11-22-2006 09:43 PM
I would like some info please Blue GT 5.O The Bar 8 04-01-2004 08:27 PM
PI head/Intake Swap Info needed bluemustang 1996-2004 Mustang GT 7 02-28-2004 10:17 PM
10:17 PM
