cant get crank pulley off - Mustang Evolution
Old 03-08-2006, 09:38 PM   #1
Thomas91169's Avatar
just as the title says. finally installing my March UDP's but i cant get the goddamn bolt off the crank pulley.
any suggestions or am i just being a n00b?
-Thomas-
Old 03-08-2006, 09:41 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: cant get crank pulley off
A lot of directions say you can do it by hand with a breaker bar, but I found that is impossible. You will need an impact wrench to break it loose.
DarkShadow is offline   Reply With Quote
Old 03-08-2006, 09:57 PM   #3
Put the car in 5th gear and have a few guys standing around to take turns on it. I installed one of these on a 2000 GT sunday...we got it off by hand, but by God it's a major PITA.
Old 03-08-2006, 10:13 PM   #4
You need a whole lot of leverage
Old 03-08-2006, 10:17 PM   #5
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
breaker bar helps
19ClearCobra96 is offline   Reply With Quote
Old 03-08-2006, 10:39 PM   #6
Yea we just installed one on my 2000 gt like lowflyin said and it was hard as piss but you can get it off by hand but it will take a lot of ppl like he said pullin on the sob. oh yea and have a strong mofo that elps too
Joshs00stang is offline   Reply With Quote
Old 03-08-2006, 11:14 PM   #7
well the breaker bar/leverage didnt work. had the car in 5th and it was moving it with the ebrake on.
so we got out the trusty air tools. the bolt laughed at it and said "no *****".
so we got the air gun. but it wouldnt fit, so we had to take off the fan shroud and assembly to make room. the bolt laughed at that as well, which is when i came on here and posted up.
well i did some more searches on other forums, and heard a loud "WOOHOO" from the garage. low and behold, the bolt finally gave in after a good 2 full minutes of constant impacting.
pullies are installed, yada yada yada. i didnt feel much of anything really, then again, i dont expect much of anything from boltons. mightve gained some torque down low cause the car felt a bit more balsy when going from 1st to 2nd at low rpm's at WOT. feels the same from 2-5k. 5k+ is the same old engine starving for air feel that us 2Vers must deal with.
-Thomas-
Old 03-09-2006, 12:29 AM   #8
Auto zone rents free harmonic balancer pullers, i spend over a hour trying to get mine off by beating it with a rubber hammer and it didnt budge, but i got it off in like 10 minutes with the harmonic balancer puller.
neatofrito1618 is offline   Reply With Quote
Old 03-09-2006, 09:54 AM   #9
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
for future reference
I saw somebody who actually used a breaker bar, extension, and jack
they put the jack under the extension and got the bolt off that way
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 03-09-2006, 10:41 AM   #10
^^ ive actually thought of doing that myself lol
Old 03-09-2006, 09:44 PM   #11
that was the easy part. i already have a pulley puller, that i know how to use. and being i had air tools, i assumed the crank bolt was going to take mere seconds, and the whole job was going to be cake. stupid bolt. other than that bolt, its pretty easy. the new pulley(with old balancer attached) slid in no problem, and yes, i remembered to sillycon the key groove.
-Thomas-
Old 03-11-2006, 10:27 AM   #12
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
yea, when i did my udp, the crank bolt didn't want to break loose either. so i took it to matt and had him do it
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-11-2006, 10:29 AM   #13
Also, you can't get the old pulley off with 2 arm puller, we finally gave up on that and bought a 3 arm puller.
Old 03-13-2006, 01:24 AM   #14
yeah, theyre like 10 bucks at ricerzone for a decent set.
-Thomas-
Old 03-15-2006, 07:15 PM   #15
MonteCitan's Avatar
I never felt that after my tuner and shorty headers..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-15-2006, 07:49 PM   #16
Region: Hawaii
Alot of you guys mentioned a breaker bar,(for future reference) if you don't have access to air tools what you need is a cheater bar, 1 inch dia iron pipe about 12 to 24 inches long. Works like a charm! I am lucky to have a old condemned Aircraft torque wrench that has a 2000 ftlbs setting on it with a 1/2 inch drive on the end of it. It's about 36 inches long. It can remove anything as long as the sockets holds.LOL
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 03-15-2006, 08:12 PM   #17
MonteCitan's Avatar
bolts are likely to snap at that rate.. that's awesome though.. that thing must weigh a friggen ton
Old 03-15-2006, 10:23 PM   #18
Region: Hawaii
Yeah, once it is on you can usually one hand it!
Old 03-22-2006, 01:18 AM   #19
i have a 4' long 2.5" dia pipe leftover from my custom fmic install, that i stuck on the end of my 1/2" driver and it did absolutely nothing but move the car forward, even in 5th gear it was moving a good 1/2" when we put strain on it. it was seriously stuck on there, prolly the most stuck-in bolt ive ever crossed paths with, usually my air tools make short work of almost everything.
sometimes patience and letting the air ratchet do its job prevails over brute strength.
-Thomas-
Old 03-22-2006, 01:22 AM   #20
jimmy_beaner's Avatar
Region: Iowa
lol, GROW SOME NUTS.... hahaha, did I say that? I know when we were taking apart my old 4.6 in my truck... I was turning over the engine while removing it... and after the engine locked up (I know, probably not the best...) I did end up busting the **** out of a knuckle.. but I got that damn bolt. I forget how big the cheater bar was.... but wow... yeah. I split the skin on my thumb down to the bone when the bolt finally did move.
Old 03-22-2006, 03:26 PM   #21
brains over brawn works every time.
-Thomas-
Old 03-22-2006, 08:02 PM   #22
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
I forget, is that reverse threaded?
232stang01 is offline   Reply With Quote
Old 03-23-2006, 09:57 PM   #23
MonteCitan's Avatar
no
Old 03-23-2006, 10:25 PM   #24
232stang01's Avatar
see, it'd have taken ME even longer.
March underdrive crank pulley Torchred02 1996-2004 Mustang GT 4 01-23-2007 03:09 PM
94-98 Underdrive Crank Pulley dapack69 Mustang Parts for Sale and Wanted 0 09-29-2005 11:09 PM
Removing crank pulley on 87 lx 5.0 5 speed WhiteStang99 1979-1995 Mustang GT 9 08-30-2005 08:59 PM
removing crank pulley... MonteCitan 1979-1995 Mustang GT 15 03-01-2005 11:48 PM
differences betwen 4.2 and 3.8 crank Pulley? Horse Pre-2005 V6 Mustang 3 07-14-2004 10:24 AM
07:11 AM
