Accelerates - Mustang Evolution
Old 02-19-2010, 04:35 PM   #1
Mustang_GT's Avatar
Accelerates
This is my first time asking. When I'm driving before I get to a stop sign I will put it in neutral going like 5miles p/hr and my car will accelerates to 1500 RPMs by itself once I hit the brakes to a complete stop it will go down to 500rpms, anybody knows whats wrong??
2002 Mustang GT
,Manual Transmission.
Mustang_GT is offline   Reply With Quote
Old 02-19-2010, 05:01 PM   #2
hottcobra's Avatar
Re: Accelerates
that is a normal condition on a fuel injected car.
Old 02-19-2010, 11:35 PM   #3
Mustang_GT's Avatar
Re: Accelerates
But it wasn't doing it before, they told me that there was a misfire on bank 1 and to check the maf sensor P1151 and P1131 codes. I checked the spark plugs and the maf sensor then I reset the check engine light and it went off but now its doing this crap..when I step at the brake it stays accelerated I can say it takes a while to drop to normal 500 Rpms????
Old 02-21-2010, 06:21 AM   #4
edross's Avatar
Re: Accelerates
my 2000 ranger does the same thing, i think its build-up in the throttle body not letting it close properly, get a can of carb cleaner and spray the linkage and inside the throttle body see if that helps, works on my ranger
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 02-21-2010, 09:45 AM   #5
Re: Accelerates
there is an idle decay rate variable that can be modified, this controls what you are doing, but if the ecu cant get clean signals it can take input wrong and idle the car higher or so. Clean your maf and your IAC (idle bypas valve, cylinder shaped thing on or near upper intake/throttle body)
clean with on contact NO residue electronic parts cleaner.
Old 02-21-2010, 03:27 PM   #6
Mustang_GT's Avatar
Re: Accelerates
thanks Spectorv -The hose was damaged and leaking air from the IAC I just replaced it and its all good.
2002 Mustang GT, Full Roush kit, Side Exhaust, Flowmaster 40 Series, BBk cold Air intake.
10:43 PM
