sourcing parts for engine build - Mustang Evolution
Old 02-25-2010, 09:36 PM   #1
upton7's Avatar
if i go with the trick flow intake manifold it uses the dual blade tb and i would need a 99-01 cobra cai r there any that dont go down inside the fender well?
Old 02-25-2010, 09:40 PM   #2
Re: sourcing parts for engine build
JLT PERFORMANCE, Home of the JLT TRUE COLD AIR KIT
Their Rai kit doesn't go into the fender. That's what I have on my car. See my album for pics.
Old 02-25-2010, 09:54 PM   #3
upton7's Avatar
I saw that and only reason I shyed away from it is because it doesnt have that little "barricade" or whatever around the filter like the trick flow and k&n. Would that barrier help much?
Old 02-25-2010, 09:58 PM   #4
upton7's Avatar
Damn this might get a little involved. The cobra throttle body doens't sit at the same angle as the gt's.
Old 02-26-2010, 12:00 AM   #5
Zim
You want to **** me?
Zim's Avatar
What barrier are you talking about? A metal shield around an air filter?
I like toys
Old 02-26-2010, 08:29 AM   #6
A. That "barricade" is useless and only restricts airflow by blocking off 2 of the 4 sides of the intake from free access to air.
B. Did you go to the website? JLT Heat Shield (1996-04 Cobra/GT) [P-HSJLT101] - $25.00 : JLT PERFORMANCE, Home of the JLT TRUE COLD AIR KIT
C. I lose zero power on the dyno when I took the shield off.
Old 02-26-2010, 09:46 AM   #7
upton7's Avatar
Does yours attach to the fener at all of does it just lay there?
Old 02-26-2010, 09:46 AM   #8
upton7's Avatar
Yes I went to the website
Old 02-26-2010, 09:48 AM   #9
It just lays there. There's no need to attach it to the fender well. All that does is make it rigid so that when your motor torques over it can slowly loosen the connections.
Old 02-26-2010, 09:51 AM   #10
upton7's Avatar
Have you ever had a problem with it like if you hit a bump and the filter bounces and it might damage something?
Old 02-26-2010, 09:56 AM   #11
My filter has about 1/8th of an inch to move upwards. Keep in mind, while it may appear to just "lay there", it is actually up under where your headlight attaches to the car. For example, there is about 1.5-2" of filter you can't see in my engine bay. It won't just flop around loosely. Also, even if it were fully loose and not blocked by the headlight, it wouldn't move far at all. It's not a wet noodle at all. With all the connections and what not, it is relatively rigid.
Old 02-26-2010, 10:38 AM   #12
i would keep it simple, keep the air filter in the engine bay with a surround as most have, when you start putting it in the fender the fitment has to be much closer.
Old 02-26-2010, 10:39 AM   #13
That's what he is looking to do actually. lol
However, the surround is useless and just restricts airflow to the filter.
Old 02-26-2010, 11:20 AM   #14
upton7's Avatar
Ya the main reason I want it in the engine bay is wiggle room for fitment. The 5.4 sits higher and the trick flow plenum may be closer or farther or whatever.
Old 02-26-2010, 12:05 PM   #15
upton7's Avatar
Well i looked at summits magazine for a little bit and i can use a regular 75 mm throttle body. It said if go with the twin blade i would need a 99-01 cobra 57 mm throttle body bullit throttle and cruise control cables and intake tube? Would the twin throttle body help that much?
Starting to build engine. upton7 General Mustang Discussion 2 07-21-2010 06:46 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
Need engine build(er) advice. PureVenom 1979-1995 Mustang GT 22 09-17-2005 11:37 AM
various v6 engine parts knife13 Mustang Parts for Sale and Wanted 0 03-02-2005 06:26 PM
questions about engine parts Johnny D Pre-2005 V6 Mustang 3 02-08-2004 12:03 PM
08:27 PM
