some dyno time - Mustang Evolution
Old 04-01-2006, 11:26 PM   #1
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
some dyno time
well after a few hours at EJ's, I have been bumped up to 384 rwhp and 361 rwtq from the previous numbers of 371/355
the timing is no longer limited to 13 degrees now that it is getting true temperature readings with the IAT right before the throttle body instead of before the blower!
I'm still running out of fuel pump at the end but the injectors are giving me enough fuel for it to go rich at 5600 rpm
I'll have to pick up that 03 cobra fuel setup one of these days and take care of that issue
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 04-02-2006, 03:23 AM   #2
Re: some dyno time
Cool stuff man
Old 04-02-2006, 12:48 PM   #3
Re: some dyno time
here's the numbers plotted in excel
Name:	dyno chart.jpg
-Adolf Hitler, 1935
Old 04-02-2006, 09:40 PM   #4
Send a message via AIM to tedness
Re: some dyno time
nice torque powerband.
tedness is offline   Reply With Quote
Old 04-02-2006, 10:25 PM   #5
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: some dyno time
Nice numbers! What kinda setup do you have?
12second5.0 is offline   Reply With Quote
Old 04-02-2006, 10:37 PM   #6
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: some dyno time
Nice. That is one awesome GT.
Old 04-03-2006, 08:08 AM   #7
Re: some dyno time
be careful though seems when the GTs start to reach 450rwhp~ they start to blow even with a good tune, you still have room though.
Old 04-03-2006, 08:13 AM   #8
Zim
You want to **** me?
Zim's Avatar
Re: some dyno time
man I wanna see your car sometime... you should drive down to KC next saturday and come to our get-together at hooters. I can provide you with a place to sleep if youd be up for it
I like toys
Old 04-03-2006, 08:38 AM   #9
Re: some dyno time
oh, I know.
I'm not adding anymore power until I have the internals and fuel system to handle it.
My fuel pump is maxed out now anyway so I couldn't push the power anymore if I wanted to.
-Adolf Hitler, 1935
Old 04-03-2006, 08:39 AM   #10
Re: some dyno time
I'd be all over it if I could afford to make the trip. You should go to WFC in may though
-Adolf Hitler, 1935
Old 04-03-2006, 08:45 AM   #11
Zim
Zim's Avatar
Re: some dyno time
I plan on it as long as I don have any finals or anything
I like toys
Old 04-03-2006, 02:39 PM   #12
Re: some dyno time
Look for me there
-Adolf Hitler, 1935
Old 04-03-2006, 02:56 PM   #13
Re: some dyno time
"Brokeback Mustangs"
Old 04-04-2006, 11:28 AM   #14
Zim
Zim's Avatar
Re: some dyno time
I wish I knew how to quit you!
I like toys
Old 04-04-2006, 12:07 PM   #15
Re: some dyno time
a shotgun works
-Adolf Hitler, 1935
Old 04-28-2006, 02:18 PM   #16
bullitt482's Avatar
Re: some dyno time
Actually I've seen several Mach's with a good tune run 450 whp no problem. Have to remember that the Mach's have a cobra crank, which is a lot stronger than a GT crank..
Old 04-28-2006, 02:32 PM   #17
I liek gramer
WhiteStang99's Avatar
Re: some dyno time
^ Yeah... So that explains why he didn't say Machs start to blow at 450. The Mach engine is almost a completely different animal.
Old 04-28-2006, 02:59 PM   #18
Re: some dyno time
yea, he has a GT 2v motor, not the mach engine
Old 04-28-2006, 04:46 PM   #19
01mineralgrey6's Avatar
Re: some dyno time
Nice man. Your running a vortec right?
-Tony
'99 cobra 'vert
Old 04-29-2006, 01:31 PM   #20
Re: some dyno time
the crank isn't the weak link, it's the pistons and rods. The mach has the same pistons and rods with different compression so I wouldn't push one of those much past 450 either
I have an aftercooled vortech system that runs around 10 psi at 6K rpm
-Adolf Hitler, 1935
Old 05-01-2006, 02:15 PM   #21
bullitt482's Avatar
Re: some dyno time
Oh ok, I was thinking that you had the mach... I guess I can't read "MachGT" :hammer: My bad... Yeah, the hypereutectics are quite weak along with the powder rods. It's really the detonation though. Spark knock commonly cracks in between the top and 2nd ring on the piston, so you end up pulling the heads off and not be able to tell where you are losing compression. A friend of mine did that with 150 on an auto 02 GT....... He never backed his timing down
Old 05-01-2006, 09:41 PM   #22
Re: some dyno time
Yeah, the mach has the same crank as the GT does though. the pistons have a different dish on them for higher compression but the shortblock is basically the same.
-Adolf Hitler, 1935
Old 05-01-2006, 11:49 PM   #23
Re: some dyno time
Very nice numbers for a GT! Must be fun to drive. What did it take to get there?
In2dreamingbig is offline   Reply With Quote
Old 05-03-2006, 06:40 AM   #24
Re: some dyno time
I've got around 11K into the car in mods so far....
the blower kit was around 5K when all was said and done
-Adolf Hitler, 1935
DYNO TIME silverstangboy 1979-1995 Mustang GT 8 06-29-2007 04:55 PM
Dyno Time Zim The Bar 39 06-28-2005 01:44 PM
dyno time costs? charkelly9 Pre-2005 V6 Mustang 8 02-22-2005 04:39 PM
dyno time 99 gt greg_g70 1996-2004 Mustang GT 24 01-03-2005 05:02 PM
Great Time At Team Ford in Marietta, GA Superchip Dyno Danger Dude The Bar 10 11-20-2003 05:26 PM
08:14 AM
