2002 4.6 and a T-5? - Mustang Evolution
Old 02-26-2010, 10:37 AM   #1
2002 4.6 and a T-5?
Can this be done? Or would I have to just man up and get a TR-3650? Also, after doing a little research, it seems the t-45 bolts up as well. I guess if I did go this route I could just switch to that, or change the bellhousing/crossmember/input shaft. Am i on the right path or way off? Btw, I don't know **** about the 4.6 as I'm a v6 owner.
19Delta is offline   Reply With Quote
Old 02-26-2010, 08:27 PM   #2
big show 98's Avatar
Re: 2002 4.6 and a T-5?
I would use the T-45, it shifts alot better than the 3650.
big show 98 is offline   Reply With Quote
Old 02-26-2010, 08:38 PM   #3
Ok, so there's no way to use my existing T5 with it?
Old 02-26-2010, 08:40 PM   #4
The 4.6 & 3.8 have different bolt patterns. Your T-5 will work with a 5.0
Old 02-26-2010, 09:33 PM   #5
I found a t45 for 250, used of course. I'm looking at right around 1k for engine and tranny, so I don't think it's too bad of a deal. I'm probably looking at another 1k-1500 for labor to install it, correct?
Old 02-27-2010, 03:18 AM   #6
Pull the 3.8 with the trans & drop the 4.6 right back in it's place. Will need the crossmember & driveshaft for the T-45. You will also need several other parts to complete the swap. V8 throttle cable, fuel lines, 4.6 brake booster, engine & computer harness with the computer & matching dash cluster, radiator & fan, midpipe. If you have the tools, time and place to do it, save the labor cost.
New Member 2002 GT Leonard New Member Introductions & Greetings 11 09-03-2009 01:15 PM
05-07 fit on a 2002? jmp782 Mustang Wheels & Tires 14 01-27-2008 10:54 AM
2002 Mustang GT saleen0027 Mustang Parts for Sale and Wanted 1 01-11-2006 02:35 AM
2002 GT parts jimmy_beaner Mustang Parts for Sale and Wanted 27 07-22-2005 02:26 PM
2002 exhaust k8338j Pre-2005 V6 Mustang 7 10-30-2004 09:50 AM
11:49 PM
