4.6 to 5.0 tranny ? - Mustang Evolution
Old 03-06-2010, 09:36 PM   #1
4.6 to 5.0 tranny ?
I have a 5 speed out of 4.6 can it bolt up to a 5.0?, this is probably a dumb question but I am a fox body guy and don't know to much about the 4.6.
Thanks for the help
chris r is offline   Reply With Quote
Old 03-06-2010, 09:46 PM   #2
Re: 4.6 to 5.0 tranny ?
The 4.6 takes either the t45 or TR3650, where the 5.0 takes the T5.
19Delta is offline   Reply With Quote
Old 03-06-2010, 09:48 PM   #3
Thanks for the info.
Old 03-06-2010, 09:59 PM   #4
No problem, I had the same questions a few weeks ago.
Old 03-10-2010, 02:34 PM   #5
OsirisGuy's Avatar
Hmm. I thought the T45/T5 transmission was the same, the T5 is just an updated version.
I know you would need a different bellhousing, and I would think a different shaft.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 03-10-2010, 05:55 PM   #6
big show 98's Avatar
The 4.6 & 5.0 have different bolt patterns on the back of the block. The t-5 for the fox bodies & the 94-95 gt's are the same with the exception of the input shaft is about 5/8" longer due to the shifter placement on the 94-95's. The bell housing for a 94-95gt will be needed when using a 94-95gt & 94-04 v6 t-5. The 3.8 has it's own bell housing for the clearance of the 11" clutch. The 94-04 v6 t-5's are the same as the 94-95gt but the gear set is different in the v6 trans ( may be weaker ) Also the 99-04 v6 trans have a different speedo set up in the rear tail shaft for the newer cars but can be converted to be used in the older models. The 4.6's have the t-45's & 3650's. (96-04)
big show 98 is offline   Reply With Quote
How to tell what tranny I have? Foxone Pre-2005 V6 Mustang 3 10-10-2009 10:12 AM
tranny help prive 1979-1995 Mustang GT 3 01-17-2009 10:44 AM
c4 tranny ryanxstang Pre-2005 V6 Mustang 11 08-20-2008 04:53 PM
tranny fsst93gt Regional Mustang Discussion 1 02-02-2006 03:08 PM
What Tranny? Smokedya95stang Pre-2005 V6 Mustang 7 03-20-2004 05:06 PM
07:48 AM
