It Has Begun!!!!! - Mustang Evolution
Old 04-29-2006, 09:47 PM   #1
Region: Hawaii
It Has Begun!!!!!***Pics inside***
It has begun. With about seven hours of work i pulled everything from the engine back minus the rear end Radiator has been pulled. The motor has been separated from the harness A/C lines and Fuel lines and all fluids have been drained. On a installer note the t-5 tranny is so light, you can muscle it by hand without a tranny jack. I got it chained up where the A/C pump bracket bolts to the head and one of the top tranny bolt holes. It's coming out first thing tomorrow. I will post some picks tomorrow when I'm finished.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 04-29-2006, 09:53 PM   #2
Thomas91169's Avatar
Re: It Has Begun!!!!!
dam nice work dude
-Thomas-
Old 05-01-2006, 09:31 AM   #3
MonteCitan's Avatar
t5s are LIGHT
good luck with everything man!!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-01-2006, 10:47 AM   #4
powerhungry966's Avatar
Send a message via AIM to powerhungry966
oo weee.. keep us posted good luck
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 05-01-2006, 10:56 AM   #5
yea t-5s are suprisingly light, I picked my spare one up with out much of a problem. What are they like 95lbs with fluid?
Old 05-01-2006, 01:08 PM   #6
Region: Hawaii
Here are some pics. I would warn you guys to check your harness at the rear where it enters the engine bay behind the shock tower. The big connector that sits vertical, well on the female side under the connector mines had about 3 ounces or more of water in it. Between the tape and the wires. We get alot of rain here in very short periods which probably contributed to it, but something like this going unchecked could cause problems in the future.
Name:	ENGINE SWAP 001.jpg
Name:	ENGINE SWAP 002.jpg
Name:	ENGINE SWAP 003.jpg
Name:	ENGINE SWAP 005.jpg
Name:	ENGINE SWAP 006.jpg
Name:	ENGINE SWAP 007.jpg
Name:	ENGINE SWAP 008.jpg
Name:	ENGINE SWAP 010.jpg
Old 05-01-2006, 01:16 PM   #7
nice
Old 05-01-2006, 02:31 PM   #8
bullitt482's Avatar
I could almost swear they stopped using t-5's in like 94-96 area. I thought you would have a t45???? Just wondering..
Old 05-01-2006, 02:33 PM   #9
01mineralgrey6's Avatar
they used the t-5 in the v6
-Tony
'99 cobra 'vert
Old 05-01-2006, 07:05 PM   #10
Region: Hawaii
Naw it was a t5 in all of the v6's. They put a T45 in the 99 gt and stopped somewhere in 01 where they went to the tremec. The input and output shaft are different compared to the fox body and sn-95 v8 stangs. I will post closer pics of the T5 later.
Old 05-01-2006, 07:31 PM   #11
Thats what i was saying the T5 had come out of you 99 V6 you got there. mid 01 they went to the 3650. oh, and the t5, t45,t3650,t56, etc, are all tremecs But I must say it looks like you got a good bit of work done in one day
-Tony
'99 cobra 'vert
Old 05-03-2006, 12:50 AM   #12
Region: Hawaii
I have been slacking on the pictures, i will try to get some tomorrow, anyway i got the motor and the tranny out of the gt. They got this monster air/hydraulic tranny lift. it made getting the tranny out pretty easy. After that i removed the motor from the top. I was working on the steering rack swap when i stopped. I will try to get some pics tomorrow.
Old 05-03-2006, 08:31 AM   #13
i think they are still using t-5s unless the 05's got the t-45 as well (and very well may have) I know up until 04 they put t-5s in the v6s and they were one of the best/strongest ever made the only problem is in 99 they swaped to a digital readout so you have to swap tailshafts with a pre 99 car to get it to work right~ but no big deal.
Old 05-03-2006, 09:10 AM   #14
bbunt302's Avatar
06 V6's still come with the T5. The T5 shall never die!!!
Scary stuff.
Old 05-03-2006, 04:09 PM   #15
didnt know that. guess theyll be around for ever!
-Tony
'99 cobra 'vert
Old 05-06-2006, 11:14 PM   #16
Region: Hawaii
I finished the major stuff on thursday. The motor, tranny, rearend are all in. The car is back at my house now to do the little stuff, since the do it yourself garage was charging $24 a day per car it was getting expensive. All i have left is to bleed the brakes and bleed the hydroboost and install the radiator. Oh and also get the key reprogrammed. I will post some pics tommorow
IT HAS BEGUN! VCS_SSSTANG Pre-2005 V6 Mustang 11 08-25-2008 10:15 AM
So the tear down has begun NorwegianMustang Pictures and Videos 4 05-27-2005 06:25 AM
The stroker has begun! Horse Pre-2005 V6 Mustang 29 06-27-2004 10:00 AM
Autocross Season has begun! Horse General Mustang Discussion 9 04-30-2004 06:44 AM
Springtime modding has begun.. stangin99 The Bar 1 02-22-2004 12:08 PM
07:55 AM
