MGW shifter - Mustang Evolution
Old 03-29-2010, 08:46 PM   #1
MGW shifter
I am halfway through installing the mgw shifter. Is it necessary to do the shift stop step. I thought I remember a thread on it but I do not recall what was said. Any help be great thanks, Jerry
JerryK123 is offline   Reply With Quote
Old 03-29-2010, 08:52 PM   #2
upton7's Avatar
Re: MGW shifter
Yes thats what protects your trans from over shifting.
Old 03-29-2010, 08:54 PM   #3
upton7's Avatar
Re: MGW shifter
back the bolts all the way off then shift into 4th. Tighten the bolt up till it barley touches the shifter handle. Back the bolt off just barely like to where you could only get a dime through it. Shift into third and do the same thing.
Old 03-30-2010, 07:29 AM   #4
Re: MGW shifter
technically its not useful to do it on a T-5 or T-45 (or T-56 for that matter) or any variant... basically any newer Mustang (which your 99-04 falls into) as you have internal bump stops... and if you shift hard enough to need them... you are doing it wrong.
If you are a only weekends hard core drag racer sure... but if its a daily driver put them in but make SURE they are quite far away from the shift lever and the jam nuts are tight so it cant move. They can mess up the transmission if to close.
Old 03-31-2010, 04:56 PM   #5
upton7's Avatar
Re: MGW shifter
didn't know that NICE!!!
Old 03-31-2010, 07:02 PM   #6
MonteCitan's Avatar
Re: MGW shifter
Also note, when you're adjusting the stops, HOLD the lever in place with a bit of force (not too much)
I don't know how I'm 'doing it wrong' I guess but I have wear marks from the shift stops.. I tend to shift pretty quickly
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Another new MGW shifter install thread bbunt302 1979-1995 Mustang GT 2 01-19-2006 10:38 PM
Newest MGW Shifter! Matt@StangMods The Bar 18 08-23-2005 03:40 PM
Ordered my MGW shifter today Zim Pre-2005 V6 Mustang 21 06-19-2005 02:24 PM
what MGW shifter to buy? Sublime782 Pre-2005 V6 Mustang 3 06-13-2005 03:52 PM
MGW Short throw shifter... Barry The Bar 8 10-14-2004 08:53 PM
10:43 PM
