Brake problems - Mustang Evolution
Old 04-04-2010, 04:30 PM   #1
67mustang97's Avatar
Region: Vermont
Brake problems
I just installed front pads and rotors now the passenger side front sticks. They work fine until you step on them hard then it will stick. Both pistons slide in freely and the slides are in good working order. I took it apart 5 times and can't find the problem I'm using Hawk HPS pads with Brembo cross drilled rotors. Need help before the car goes on craigslist!
Old 04-04-2010, 08:08 PM   #2
MonteCitan's Avatar
Re: Brake problems
Have you tried dielectric grease on the caliper slide pins?
The pistons may slide freely on first attempt, but how do the bores look? I'd be willing to bet there's corrosion and a 'ridge' built up inside the bore or on the piston.. Does your car have ABS? It could even be a sticking valve in the actuator not allowing pressure to release after ABS activates (easiest way to check this would be pull the ABS fuse, go stop hard - without wrecking of course - and without having ABS kick in, and see if the caliper still sticks)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-04-2010, 08:21 PM   #3
Region: Vermont
Re: Brake problems
I do have ABS. I'll try pulling the fuse. Thanks
Old 04-05-2010, 04:53 PM   #4
Region: Vermont
Re: Brake problems
Should both pistons in the caliper move the same amount with no resistance?The piston closest to the brake line goes out twice as far.
Old 04-06-2010, 06:39 PM   #5
Region: Vermont
Re: Brake problems
Problem solved replaced the caliper no more sticking! Must be from sitting this winter car only has 33K.
99 35th. ann. GT brake problems !! HELP!! plz j4gwig 1996-2004 Mustang GT 6 06-22-2010 05:28 PM
Brake Problems LSUstang Pre-2005 V6 Mustang 9 06-20-2009 05:21 PM
Brake Problems on a 71 Mach 1 71 Mach 1 Classic Mustangs 6 04-18-2009 06:54 PM
V6 Mustang Brake Booster Problems Brent Pre-2005 V6 Mustang 24 11-05-2007 08:38 PM
03:12 PM
