Wheel Bearings - Mustang Evolution
Old 04-05-2010, 11:12 PM   #1
Mustang1804's Avatar
Send a message via AIM to Mustang1804 Send a message via Yahoo to Mustang1804
Wheel Bearings
I have been hearing some kind of humming noise coming from the left front side of the car and the last mechanic I saw a while back told me it was probably the wheel bearings. I was wondering 1.) how hard it would be to change wheel bearing? and 2.) roughly how much should a mechanic charge
Mustang1804 is offline   Reply With Quote
Old 04-07-2010, 05:16 AM   #2
02MGGT's Avatar
Re: Wheel Bearings
It's not that hard to change out the front wheel bearings. They come sold as a hub. The only problem is that they need to be torqued to 250 ft-lbs which most common torque wrenches can't measure. I found that its the same brand from napa or ford.
I be Trollin' Mon
02MGGT is offline   Reply With Quote
Old 04-07-2010, 03:02 PM   #3
Re: Wheel Bearings
Really damn. Ok.
Old 04-07-2010, 06:28 PM   #4
edross's Avatar
Re: Wheel Bearings
its not very hard to do, i bought an impact wrench and did it myself
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 04-08-2010, 12:12 PM   #5
Re: Wheel Bearings
Well im new to the whole DIY repairing, just ordered some tools online actually. I was actually gonna try and have a local shop do it. How long did it take u to do it? How much u think a local shop will do it for?
Old 04-08-2010, 01:31 PM   #6
Re: Wheel Bearings
do you have to slide the axle out to get to the bearings?
Old 04-08-2010, 02:51 PM   #7
Re: Wheel Bearings
To my knowledge, no I dont think so
Old 04-08-2010, 02:55 PM   #8
02MGGT's Avatar
Re: Wheel Bearings
Are you looking to replace the front or rear?
Fronts are easy, the rear not so much.
I be Trollin' Mon
Old 04-08-2010, 02:59 PM   #9
Re: Wheel Bearings
Im looking to get the fronts replaced
Old 04-08-2010, 04:20 PM   #10
edross's Avatar
Re: Wheel Bearings
it depends on hourly rate, i did mine in about an hour per side, get yourself a haynes manual and save some money
Old 04-08-2010, 07:13 PM   #11
Re: Wheel Bearings
Don't got adequite tools yet, just ordered some online though and idk like I said in earlier threads/posts, im still new to DIY auto repair, im not nearly as advanced as most of u guys, somewhat nervous about doing certain repairs such as breaks or wheels so idk
Old 04-08-2010, 09:14 PM   #12
Re: Wheel Bearings
I always find the key to doing something for the first time is to take your time, never rush into it and dont have a deadline to get it done. If you come up on something that doesnt seem right, take a step back and think about it and read up online etc... dont break something or mess something up just because you didnt take a couple minutes to think about it.
Old 04-11-2010, 11:05 AM   #13
Re: Wheel Bearings
Definitely understand that. Thanks for the tip. ill come back if I got questions, thanks.
Wheel help 68dreamer Mustang Wheels & Tires 1 12-14-2010 11:13 PM
front wheel bearings 98mustang2007 1996-2004 Mustang GT 1 08-20-2010 10:19 AM
SPEC Flywheel, pressure plate, disk and bearings Foxone Mustang Parts for Sale and Wanted 1 07-19-2010 05:36 PM
bearings/ball joints in the rear tigerfan2771 Pre-2005 V6 Mustang 5 08-06-2008 07:19 AM
Wheel Bearings? Thomas91169 Mustang Wheels & Tires 6 09-06-2006 12:11 AM
08:25 AM
