Takes 2-3 times to crank, wtf? - Mustang Evolution
Old 06-07-2006, 06:48 AM   #1
ridenmystang's Avatar
Here lately something has been wrong with my car and its quite embarrassing! I'll get in, try to crank it but it wont, I'll try again and it won't, it ususally take 3 times.... and by this time I'm ready to kick the crap out of it. I thought maybe it needed new spark plugs so I changed them... still wont crank correctly. It only does it sometimes. Then I thought maybe its the gas.... I dunno. What the hec is it?
ridenmystang is offline   Reply With Quote
Old 06-07-2006, 07:50 AM   #2
Kiljosh's Avatar
Re: Takes 2-3 times to crank, wtf?
Make sure your new plugs are gapped, also how long since the air filter been
changed.
Does this happen whenever you try to start it? First thing in the morning? When the car is aready hot?
Old 06-07-2006, 08:38 AM   #3
check plugs/plug wires/coil pack/starter/fuel filter maybe~ or fuel delivery system~
Old 06-07-2006, 11:59 AM   #4
Region: Hawaii
Is it when it's warm driven already, or cold first thing in the morning?
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 06-07-2006, 12:00 PM   #5
Well really It happens any time, In the morning or it will happen when I've drove it around a bit... Like I got off work got in and it crunk right up... Drove around a while, went to the gas station got back in and it took me 2 times to crank it.... peice of crap..........
Old 06-07-2006, 12:24 PM   #6
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I would check your battery. I had crazy stuff like that happening to me when one of the modules was pulling a tiny amount of power from my battery and slowly drained it. I was also able to drive from place to place, but then not have it work the next turn over.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 06-09-2006, 02:42 AM   #7
Kiljosh's Avatar
Clean your air filter and see if it helps. Besides that I would check the plugs and wires as forementioned.
Old 06-09-2006, 05:51 AM   #8
bbunt302's Avatar
If it does this more often after you have been driving it around for a while, it is very likely the starter going out. When they get too hot, they will often have a hard time cranking.
When this happens, does the car try to turn over and just doesn't?
Scary stuff.
Old 06-11-2006, 04:36 PM   #9
Yep
One wicked 03 GT FOBRA
Old 06-11-2006, 04:43 PM   #10
Sounds like the starter to me
Old 06-16-2006, 06:56 PM   #11
i'll tell you exactly what it is. fuel pump. mine does the same thing. found out from a mustang mechanic that there is what he called a check valve in the fuel pump. it sticks,thus letting the fuel pressure back off instead of keeping constant pressure. until you replace it cycle the key 3-4 times before you start it. off on off on etc. then start. makes it easier. hope this helps ya.
white 98 gt is offline   Reply With Quote
Old 06-17-2006, 05:23 AM   #12
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
mine does this ive found (believe me or not) i can turn the key on for atleast 5-10 seconds just on not in (crank position) and it will fire right up when i try to start it.
1996stang is offline   Reply With Quote
Old 06-19-2006, 01:18 PM   #13
john#21's Avatar
My 01 was having a problem like this on Friday. Hasn't happened again but I'll keep my eye on it.
john#21 is offline   Reply With Quote
Viper Almost Takes Out BMW Brent Pictures and Videos 4 02-15-2010 09:50 AM
T-Shirt Hell Takes Shot at Falwell Brent Pictures and Videos 15 05-18-2007 03:58 PM
Dude Takes Life on Webcam Chat *Death Warning* bluemustang The Bar 16 03-25-2007 09:25 PM
John Stewart Takes On Congress Regarding Video Games Brent The Bar 11 06-24-2006 06:08 PM
Insurgent Sniper takes down 1 soldier a shot and runs? Seph The Bar 17 01-13-2006 08:17 PM
05:41 AM
