calling dangerdude! - Mustang Evolution
Old 06-17-2006, 04:36 PM   #1
calling dangerdude!
dd, are you familiar with ford's 4.6 v8? had a coolant leak where thermostat housing meets the intake. found out the intake is cracked right there also. got one on the way. prior to my discovery i thought maybe the thermostat housing was warped, not so. it looks pretty straight forward to change. should i replace injector o rings when i take them off, or just see if they're in good shape? one guy told me i can't get replacement o rings unless i get new injectors. doesn't sound right to me. also, when i put the thermostat down into the recessed area for it, i can wiggle it side to side. almost 1/16 inch, almost. far as i know it should be pretty snug. any thoughts, advice?
white 98 gt is offline   Reply With Quote
Old 06-17-2006, 05:06 PM   #2
Danger Dude's Avatar
Re: calling dangerdude!
You can get injector O Rings seperately but personally if they are in good sondition I would use either parker lube or in a pinch some vaseline. As far as the thermostat I would use permatex sealant around the recess are and place the thermostat straight down applying pressure. when it becomes tacky place some permatex on the contact area of the housing and place it down on the theromstat and tighten down. Try not to let it wiggle
Old 06-17-2006, 07:54 PM   #3
thermostat housing has an o ring instead of gasket.tried using blue gasket maker on beveled edge of housing, held for 3 weeks. started leaking agai, that's when i found the crack. on this plastic intake the front runner is a coolant passage. on the improved intake the front passage is aluminum, the rest of the intake still plastic. where the fuel lines run to the fuel rail, it's held on by a spring lock. have a tool i used when i changed the fuel filter while back, but won't fit to unlock that spring. it's a 1/4 inch. happen to know what size? so the o rings on the fuel injectors need just a very light coating of oil or something to help when putting the fuel rail back on, right? thanks for the help.
Old 06-17-2006, 08:00 PM   #4
I would use the Therrmostat O Ring with some Permatex. I have heard of the intakes cracking there on more than one occasion. I have family in from Mobile tonight and I am head back out on the deck to do more drinking but I will look to see what size my fuel filter tool is and let you know in the morning. I also ahve a Ford Service manual I will look at. Dont use oil on the Injector O rings use vaseline or Parker O Lube O Ring lubricant
Old 06-17-2006, 08:07 PM   #5
ok. have a good time with your family, be safe.
Old 06-18-2006, 08:10 AM   #6
I have a Snap-on multi size combo fuel coupling tool so it would not help you but my Ford Service Manual says it requires a 3/8-1/2 tool. I have seen a tool like mine in a NAPA auto parts.
Name:	Snap on lFuel line spring lock coupling tool.jpg
Old 06-18-2006, 11:49 AM   #7
Did you get a new intake with the aluminum cross over?
Old 06-18-2006, 07:23 PM   #8
steve, yes i got the intake with the aluminum crossover.
dangerdude, thanks for the info.
calling ryan out! meteorachick The Bar 6 09-03-2006 08:55 AM
Calling out Sratex Brent The Bar 5 09-04-2005 10:26 PM
calling anyone and everyone out (v6 or gt) tire Pre-2005 V6 Mustang 8 04-18-2004 10:48 PM
Calling Out DarkEntity v6stanger Pre-2005 V6 Mustang 10 09-22-2003 08:32 AM
10:09 PM
