HELP check fuel cap light????? - Mustang Evolution
Old 06-23-2006, 10:21 AM   #1
Question HELP check fuel cap light?????
whats up with this light???? cap is on, car runs fine????
R1SRUNS is offline   Reply With Quote
Old 06-23-2006, 10:26 AM   #2
Re: HELP check fuel cap light?????
try taking off the negative battery terminal and sitting it to the side so it wont re-connect by accident to the terminal. Tap the brakes a few times to drain power. let the car sit for 15 minutes or so (30 if you have the time... why not) and re connect it. See if it comes back on.
Old 06-23-2006, 11:26 AM   #3
Herbstang's Avatar
If what SpectorV doesn't work You may have a problem with the cap not making a good pressure seal and the ECM detecting that.
Old 06-23-2006, 12:05 PM   #4
yup, you can then try another cap, else it may just be the sensor.
Check Engine Light Eeyore Pre-2005 V6 Mustang 10 04-09-2009 08:22 PM
Check Engine Light, Need help NOW! Mustang GT HO 1996-2004 Mustang GT 8 01-02-2009 03:09 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
check engine light mustangruss Pre-2005 V6 Mustang 1 04-02-2006 09:49 PM
04:28 AM
