Need Clutch Help!!!! - Mustang Evolution
Old 04-20-2010, 09:26 PM   #1
Exclamation Need Clutch Help!!!!
what would cause the throw out bearing to break, 6 months later the clutch shred, then 6 more months later the pressure plate mess up? When the throw out bearing went out i did not replace the clutch like a dummy. When the clutch went out the second time i replaced everything i even had the flywheel resurfaced. then i took my car to the drag races to see what she would do and shifting from second to third i messed up the pressure plate. what could cause all of these problems with the clutch? would you recommend going back with a Spec, or Ram Clutch kit? I was looking at the stage 2 for both of them any suggestions?
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
and a 18 year old adrenaline junkie :burnout:
jkaminski24 is offline   Reply With Quote
Old 04-21-2010, 04:28 PM   #2
67mustang97's Avatar
Region: Vermont
Re: Need Clutch Help!!!!
I have a Ram stage 2 clutch haven't had any problems with it yet. Who installed it maybe it wasn't installed properly...
Old 04-21-2010, 08:32 PM   #3
haha thats funny not installed right lol me and my dad did lol...
Is there an adjustment your supposed to make on the clutch? The clutch did have a little free play but i was told that it was supposed to.
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-21-2010, 08:35 PM   #4
racefan966's Avatar
Region: Idaho
No adjustment it an automatic adjustment you simply pull up on the clutch pedal then push it down if it clicks it needed to adjust otherwise it is good. It may have been a bad throwout bearing or ?
racefan966 is offline   Reply With Quote
Old 04-21-2010, 08:39 PM   #5
thats what i am hoping it is but that is the second one i have put in the car. Should i go back with the stock stuff or what should i get? Suggestions, what do you prefer?
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-21-2010, 08:41 PM   #6
racefan966's Avatar
Region: Idaho
You would have choices of clutches but this depends on how you drive it and what mods you have and what HP. Make sure the throwout bearing is the self aligning type and check the throwout bearing retainer for any wear that may have cause the bearing to go bad.
Old 04-21-2010, 08:44 PM   #7
Its an everyday driver i do push her sometimes and i do take her to the drag strip with my dad every now and then so she has a pretty rough life. I have some minor bolt ons; cold air intake, 3.73 gears, exhaust, and thats about all.
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-21-2010, 09:13 PM   #8
Region: Vermont
I'd go with a stage 2 Ram clutch I think they are rated for around 450 hp. Like I said I like mine and my car See's hard street and strip use.
Old 04-21-2010, 10:26 PM   #9
sounds good i think ill go with that one i have heard nuthing but good thing about it. How do you like your mustang? How much did you put into it if you dont mind me asking?
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-22-2010, 07:01 AM   #10
Region: Vermont
I love the car it's fun to drive! Are you talking a parts list or money invested?
Old 04-22-2010, 07:50 AM   #11
Both lol. I wanna start putting more bolt ons on mine and it looks like you got yours all fixed up just wanted to see how much you have invested.
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-22-2010, 09:53 AM   #12
racefan966's Avatar
Region: Idaho
67mustang97 is right that is a great clutch and will serve you very well.
Old 04-22-2010, 03:28 PM   #13
Region: Vermont
Most of my parts came from American Muscle. Here are my engine/drivetrain mods.
K&N FIPK Intake, Pro Products 75mm throttle body, Pro Products Intake plenum, American Muscle intake spacer, Granatelli 60K coils, NGK Iridium plugs, BBK ceramic shorty headers, BBK offroad X pipe, Flowmaster American Thunder cat back, BBK pulleys, SCT custom 93 octane tune, Spec Aluminum flywheel, Ram stage 2 clutch, Ford Racing Aluminum drive shaft, 31 spline Ford racing Cobra differential with carbon clutches, 31 spline Moser axles, Yukon 3:73's, Brembo drilled rotors, Hawk HPS pads, BBK non adjustable upper and lower control arms, Eibach lowering springs, Hurst shifter. I think that's it. Exterior not to much done Mach 1 grille, chin spoiler, tinted windows, 95 style Cobra rims, sequential tail lights I have Xenon 1/4 window scoops waiting for paint. Interior is just some bullitt pieces here and there, white face Cobra style gauges. I would say I have around 12k invested give or take with me doing most of the work. Should have saved my money for a Terminator!
Old 04-22-2010, 03:40 PM   #14
How much of a gain in hp did you see with all of the add-ons? Was it worth it or would you reccomend another route?
Have you taken her to a drag strip or you just use her for cruising around town?
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-22-2010, 03:59 PM   #15
Region: Vermont
I haven't re tuned it since coil packs, plugs throttle body and intake plenum. Before that I put 256 to the ground. My best time on the track was 13.74 @ 101. That's leaving from a idle due to hooking up problems. That's why I just did the diff, axles and control arms, I'm hoping for better 60' times. I love beating newer GT's with my 02 it's kind of fun being the underdog with only 260 stock hp. As far as recommending another route that's up to you are you still making payments? I've seen a 2 valve run 9's on youtube just depends on how much you want to spend.
Old 04-22-2010, 04:06 PM   #16
hahah nah it was a graduation present from the parents. paid in full lol. I installed new gears the 3.73 a cold air intake and an exhaust system. I took it to the track twice i ran a 13.8 so i think im doin pretty good for almost a stock GT lol. I like the power and the adrenaline rush. My dads got a Vette its fast and all but i just like the feeling of a mustang better.
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 04-22-2010, 04:12 PM   #17
Region: Vermont
13.8 is impressive for your mods! Since it's paid for I say build it.
Old 04-23-2010, 03:30 AM   #18
haha i like your style lol. now i just gotta come up with 12K. its hard for a 19 year old to hold on to money lol
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 05-04-2010, 03:24 PM   #19
i brought the clutch back to the auto parts store turns out it was a defective part so they gave me another one no charge so im back on the road..
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 05-04-2010, 03:32 PM   #20
Region: Vermont
That's good news!
Old 05-04-2010, 04:19 PM   #21
Shure is now to start saving for the upgrades!!!!
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 05-05-2010, 09:43 AM   #22
racefan966's Avatar
Region: Idaho
There are so many upgrades and power adders to you can get to. The list is almost endless.
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 12:19 PM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 12:54 PM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 04:04 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 04:21 PM
Clutch Murph00 Pre-2005 V6 Mustang 2 06-30-2004 05:00 PM
05:54 AM
