Supercharger - Mustang Evolution
Old 07-18-2006, 05:46 PM   #1
ridenmystang's Avatar
Supercharger
Ok I'm thinking about getting a supercharger. I have an 03 4.6 Gt. If I'm going to be spending thousands of dollars I want one thats worth every penny.... What should I get?
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 07-18-2006, 05:47 PM   #2
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: Supercharger
kenne bell!!!!!!
1996stang is offline   Reply With Quote
Old 07-18-2006, 06:08 PM   #3
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: Supercharger
WHIPPLE!! STFU 1996STANG 8p J/P WHIPPLE!!!... go to Google Video and type in whipple, they have an 05 gt with a whipple, sounds like a ****en spaceship wwwwooooooooooooooooooooooooooooooo... literally. sounds badass.
Cajun JungleBoy is offline   Reply With Quote
Old 07-18-2006, 06:12 PM   #4
Re: Supercharger
well i'll stick to kenne bell was actually going with whipple but i like the kb that is my opinion.
Old 07-18-2006, 06:16 PM   #5
bbunt302's Avatar
Re: Supercharger
If you want a nice street blower, go with some sort of roots-style blower. Probably either the aforementioned Whipple or Kenne Bell. If you are really serious about making the most powerful possible, go with a centrifugal like a Vortech, Procharger, or Paxton.
A roots blower will make boost throughout the powerband, even at low RPMs. So they are great for something you'll be driving every day and want just for the fun of having the extra power. If you want something to race though, a centrifugal will make more boost and power at high RPMs.
Scary stuff.
Old 07-18-2006, 09:10 PM   #6
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Supercharger
We have a poweradders forum for this
DarkShadow is offline   Reply With Quote
Old 07-19-2006, 08:09 AM   #7
Re: Supercharger
GTs dont like much over 450rwhp I would stick it at 400rwhp/tq~ you could use the money and upgrade to a better platform to start with, but that is just a suggestion.
Old 07-19-2006, 08:15 AM   #8
Re: Supercharger
do a cobra swap, then take the stock blower off and throw the whipple
Old 07-19-2006, 09:15 AM   #9
Thomas91169's Avatar
Re: Supercharger
Procharger FTW.
-Thomas-
Old 07-21-2006, 12:42 AM   #10
Send a message via AIM to Invictus Send a message via Yahoo to Invictus
Re: Supercharger
Don't listen to them..
If you have a stock 4.6 bottom end and you're looking to supercharge whatEVER you get i'd keep it under 10PSI or you could detonate and eventually blow your engine, it's rare that a unbuilt 4.6GT block takes can make 420 - 450HP reliably.
As for specific brands, definately keep away from POWERDYNE.. eww.
Personally i'd go with Vortech.. v-2 series is nice
Procharger is nice as well. Remember keep it under 10PSI!!! And whatever you do don't go over 5500RPM with the s/c
Nice ride BTW
Invictus is offline   Reply With Quote
Old 07-21-2006, 09:35 AM   #11
Re: Supercharger
invictus is right i wouldnt plan on making alot of boost on stock internals everyone ive talked to says about 400hp is the safety mark.
Old 07-21-2006, 01:32 PM   #12
Re: Supercharger
If you have a stock 4.6 bottom end and you're looking to supercharge whatEVER you get i'd keep it under 10PSI or you could detonate, it's rare that a unbuilt 4.6GT block takes can make 420 - 450HP reliably.
Nice ride BTW
Thanks. Well I was actually thinking about Vortech. Another thread I read the other day was talking badly about Prochargers. Motor wise I havent done anything yet. Its coming soon but I have no idea where to begin. I'll have to do my research.
Old 07-21-2006, 01:51 PM   #13
Re: Supercharger
Before a supercharger i'd consider getting some nice headers, and maybe even some cams. Some nice VT stage 1 cams should suite you well especially if you're thinking about s/c in the future. VT makes some nice ones and i'd recommend comp cams. I like the BBK headers but if you want to do it big get some KOOK headers =) You'll notice a huge performance increase and might actually improve your gas mileage.
Vortech is the way to go. Procharger is not bad at all, it's much more simple and rugged. Highly reliable.
Kook headers run around $900 but they're NIICCEEEE. You could probably get some BBK for around 4-500 make sure you get ceramic coated though, handles the heat much better.. Cams would probably run 5-700, if you're lucky you could get both for under 1k and you'd notice a huggee difference. You're still going to haul *** either way =)
Old 07-21-2006, 02:40 PM   #14
06steeda's Avatar
Re: Supercharger
I have the vortech sq (10psi) on my '06, other than 39# injectors and u/d pulleys, it has stock internals. I had it dynotuned by Chris Johnson from SCT. He likes the centrifugals because they build boost and are easier on internals. I'm makin' 410rwhp, which is plenty for me, I wouldn't want to go much higher without making the engine a little beefier. I think a s/c give you the best bang for the buck, just my .02.
06steeda is offline   Reply With Quote
Old 07-21-2006, 05:42 PM   #15
Re: Supercharger
nitrous will always be the best bang for your buck(unless you have a stock turbo car like a dsm or evo, in which case a 5$ boost controller can give you the greatest bang for buck mod), but the cool thing about a full-time power adder, is that its always there when you want it. you dont have to arm and hit a safety switch, open the bottle, purge, then step on it, you just hit the throttle and go.
its all about your goals. like Invictus said, Vortech or Procharger and keep it under 10psi on stock internals will make for a good setup, and you can upgrade airflow later on to give even more.
-Thomas-
Old 07-21-2006, 06:41 PM   #16
Re: Supercharger
A supercharger is definately a huge boost, full time, no doubt.. I just recommend the other mods first to see how you like it before you go with the s/c. A supercharger is a pretty extreme mod and you'll start seeing your mp/g drop like crazy! If it's worth it to you go for it!
< 10PSI !
Old 07-22-2006, 03:06 PM   #17
DarkShadow's Avatar
Re: Supercharger
Lol, for gas mileage Turbo > Super. The beauty of controlling boost.
Old 07-22-2006, 03:40 PM   #18
Re: Supercharger
Exactly. But the turbos for the modulars can get pretty expensive.. Especially on the 281s !
DarkShadow.. I just saw your CarDomain page. Thats a sick lookin pony, props : )
see mine @ Viewing profile
Old 07-22-2006, 08:41 PM   #19
Re: Supercharger
Well Every one I know around here sprays NX. I dont really think its for me. For one thing I dont want to blow up my motor hahaha. Plus I want to be able to out run someone on motor than with a nx setup. I mean dont get me wrong I like Nitrous I bought my x a second stage.... in which he sprayed a 225 shot and blew up his motor dumb@$$... anyway I really want bragging rights and I want it done perfect so I guess I need to start with heads and cam. I guess when I get it built I can start thinking about a supercharger.
Old 07-22-2006, 08:51 PM   #20
bbunt302's Avatar
Re: Supercharger
I like your thinking. To me, there's nothing better than an N/A motor that will run with most (if not all ) of the boosted guys. After all, even after you build the baddest N/A motor possible... you can always add a little boost...
Scary stuff.
Old 07-22-2006, 09:28 PM   #21
Zim
You want to **** me?
Zim's Avatar
Re: Supercharger
Ok, Im 100% serious... will you marry me
I like toys
Old 07-22-2006, 09:58 PM   #22
Re: Supercharger
Excellent.. I 100% guarantee you, you're going to notice a HUGE difference on the cams and headers. Even with those 2 mods, you're still safe to run a s/c with 8-10psi of boost. With the stage 1 cams and headers you're going to have some amazing sound as well, and with the s/c you're going to see around 430 - 450HP so don't bring it over 5500 rpm!
You'll stand with the nx guys all day =)
Old 07-23-2006, 12:29 AM   #23
timpryor's Avatar
Re: Supercharger
only bad thing about procharger is that since its self contained, it takes quite a bit more power to turn.
if i was going to S/C i'd do KB after forged internals and HCI, but thats just me. i want a turbo, just one but that will be a LOOOONG time in the future
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 07-23-2006, 12:53 AM   #24
Re: Supercharger
KB is good for low end torque.. its also a bit tougher on the internals.. all of the s/c take a resonable amount of power to turn theres no noticeable difference though. i love how the prochargers and the vortechs just pull through all the way though.. as the boost builds up it just takes off.. keeps pulling all the way.
Old 07-23-2006, 07:56 AM   #25
Re: Supercharger
centrifugal ftw!
Old 07-23-2006, 04:36 PM   #26
Re: Supercharger
controlling boost only matters at full throttle. i love it when all these guys come to the dsm boards asking if they can turn down the boost to get better mileage, and we all just tell them "stay out of boost". you will get the same mileage driving without going full throttle if youre set at 5psi or 20psi.
if you can have a light foot and keep the intake pressures down, the injectors/fuel system only has to work that much less. i used to drive the GST all day long and not go over -10hg and got great mileage. as soon as i went WOT@20psi for a few gears, **** there went 1/8 of a tank.
-Thomas-
Old 07-23-2006, 05:31 PM   #27
Re: Supercharger
Well if you are as cute as your picture than sure! hahaha I just love that hair and those teeth.....Seeeexxxy
Old 07-24-2006, 10:59 AM   #28
Re: Supercharger
Ideally you want something that is intercooled or aftercooled. KB makes a nice kit but it is pricey. The Vortech kit is available with or without an aftercooler.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 07-24-2006, 11:12 AM   #29
Zim
Zim's Avatar
Re: Supercharger
Oh you know it...
I like toys
Old 07-24-2006, 02:29 PM   #30
Re: Supercharger
Someone recommended a roots style to me the other day. Do you have any suggestions as where I could buy one?
Old 07-24-2006, 02:30 PM   #31
Re: Supercharger
Kenne Bell Web Home
Old 07-24-2006, 02:36 PM   #32
Re: Supercharger
Ok so I'm roughly looking at $5 Grand....Hmmmm Ok well Bye Bye Camaro hahaha.
Old 07-24-2006, 03:41 PM   #33
Re: Supercharger
Paxton makes an excellent blower too... Can't believe I forgot that name!
Old 07-24-2006, 04:03 PM   #34
Re: Supercharger
Yeah, forget the craparo.
Here is the perfect plan...send your engine to VT Engines to get it built and stroked 20 over to roughly 302 ci. This will include all forged internals, cams, porting, etc. Then, get the KB 2.6L that is going to be replacing the 2.2 and 2.4L offerings (not on their web page yet for some reason...but they have just come available.)
The VT buildup will run about 7900...the KB setup with BAP will tack on 3600 more....then of course the tune work.
Anyhow, this is my plan for the cobra...should be fun.
And cajun...make up your mind. You scream whipple then say centri FTW....pick one and stick with it you silly boy.
Old 07-24-2006, 08:09 PM   #35
Re: Supercharger
I like his idea if you got the money.:approve:
JROC is offline   Reply With Quote
supercharger???? bluestang1724 1979-1995 Mustang GT 21 08-02-2007 08:33 PM
supercharger??? bluestang1724 Pre-2005 V6 Mustang 6 06-11-2007 03:29 PM
SUPERCHARGER! pony rider Pre-2005 V6 Mustang 17 05-30-2007 07:44 AM
Supercharger cms09071987 Pre-2005 V6 Mustang 6 06-26-2005 07:03 PM
gt or supercharger....? chevykiller Pre-2005 V6 Mustang 13 08-14-2004 04:41 PM
04:07 PM
