give me a stroke - Mustang Evolution
Old 07-22-2006, 01:50 PM   #1
Send a message via Yahoo to o3mustangGTafs
give me a stroke
my 03 mustang gt is needing a stroke.... not really ,but i am wanting to stroke it out before adding a s/c an plus i want it to have forged internals cause i am running nitrous but i need to know whant stroker kits well work on my engine...i would like to know what i should do first stroke it out or s/c it first ... i am curently trying to run a 125 shot on it now . eny suggestions would greatly help thanks
o3mustangGTafs is offline   Reply With Quote
Old 07-22-2006, 02:40 PM   #2
bbunt302's Avatar
Re: give me a stroke
I would build the bottom end of the motor before you put the supercharger on it. I really can't help you with what stroker kit to go with, because I've never looked at any for a 4.6. Just be sure you get forged rods, piston and crank and make sure it's from a reputable company.
Scary stuff.
Old 07-22-2006, 02:59 PM   #3
thanks , can i get forged rods,pistons an crank on at a time to save money or do i have to buy them all at one time an put them on at the same time???
Old 07-22-2006, 03:13 PM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Yes, you can put them all on at the same time. They are connected so it would be much easier to do all at the same time. I also have never done any research for all that on 4.6's, but I'm sure there are plenty of good companies out there with good crank and piston sets.
Also, if you have the moeny, I would do the bottom end first, then SC.
DarkShadow is offline   Reply With Quote
Old 07-22-2006, 03:39 PM   #5
Thomas91169's Avatar
doesnt VT make the modular 5.0 stroker kit?
-Thomas-
Old 07-22-2006, 03:44 PM   #6
Herbstang's Avatar
Try here to get a idea of what's available and pricing FORD 4.6L MODULAR HI-PERFORMANCE ENGINES & KITS
Old 07-22-2006, 09:13 PM   #7
thank you very much herbstang
Old 07-23-2006, 04:20 PM   #8
It might be cheaper to buy a short block that has already been built, from a company like D.S.S., Coast High Performance, Sean Hyland Motorsport, etc. I'm not sure if it would be or not, just trying to give you some ideas to look into. And I would defanently build my engine first, then you can get a bigger blower and run more boost, you might need to invest in some head work though, like stiffer Valve springs.
JROC is offline   Reply With Quote
Old 07-23-2006, 04:39 PM   #9
thanks man i well look into that man ........ if it is cheaper i well go that route i just dont want to spend unesasry money.
Old 07-23-2006, 07:17 PM   #10
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Delk Performance check there
1996stang is offline   Reply With Quote
That's it! I ****in give up and just don't give a **** anymore SilentNoise The Bar 25 07-05-2009 04:02 PM
To STROKE or not to STROKE: 100th Topic (in ENGINE) RGR Pre-2005 V6 Mustang 10 02-14-2005 09:17 AM
can you stroke your 3.8 cjd10 Pre-2005 V6 Mustang 11 01-11-2005 04:04 PM
Just Give Up People! WhiteStang99 The Bar 83 01-08-2005 03:34 PM
If you can, please give V6STANG007 The Bar 1 12-30-2004 08:03 AM
10:36 PM
