Share your dream list of GO FAST mods... - Mustang Evolution
Old 08-04-2006, 10:14 PM   #1
Talking Share your dream list of GO FAST mods...
2:
Maybe start with:
Big *** Ford Racing Cammer blown engine assembly!
In2dreamingbig is offline   Reply With Quote
Old 08-04-2006, 11:49 PM   #2
Re: Share your dream list of GO FAST mods...
-A built short block with billet, And/or forged internals.
-Ported heads, maybe VT,or Patriot.
-Kenne bells biggest supercharger kit that they make for a 2v mod motor.
-Good cams that will work well with the other mods, probably some Comp cams.
-Anderson Ford Motorsports PMS.
-Recaro seats.
-All knew suspension and chassis part from Griggs Racing.
-Roushs big brake kit.
-Hooker Long tubes, and Dr. Gas X-pipe.
-Rollcage something thats not to inconvenient.
-A good 8.8 readend, maybe something from Strange Engineering with a good LSD and stronger 31 spline axles.
-Ford Racing aluminum drive shaft.
-D&D Viper spec T-56, or if you can get one maybe a Shelby GT500 Tranny, depending on how it compares to the Viper spec T-56.
I'm could thing of some other stuff like Fluidyne radiator, Canton oil pan, and windage tray, SPEC flywheel, and clutch, etc, etc, but that would take a while.
JROC is offline   Reply With Quote
Old 08-05-2006, 12:00 AM   #3
timpryor's Avatar
cobra 324 VT race block, P51 intake, intercooled vortech VT1, 9" rear end with 4.56's backed by a built T56 with bassani exhaust all the way back.
but thats looking like 3 years pay
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 08-05-2006, 12:50 AM   #4
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Yank 3000 torque converter
Long tube headers
ATI procharger
and maybe a new cam. That is all.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 08-05-2006, 06:56 AM   #5
bbunt302's Avatar
All forged 427 Stroker assembly in a Dart Aluminum 351 block
10:1 Compression Ratio
AFR 205 Heads
Custom Cam
Probably either a Edelbrock Vic Jr. or a TFS R Intake
Long tubes with 1-7/8" primaries and 3" exhaust all the way back
All the supporting engine stuff (TB, MAF, fuel system, etc etc etc)
Custom Tune
Viper Spec T-56 with 4:10 or 4:30 gears in the rear, whichever is about the equivalent of 3.73s in a T5.
Maximum Motorsports Maximum Grip Box (has panhard, full coil-overs, torque arm, etc)
14" Brembo Brakes in front, 13" in rear
18" Wheels (probably Roush)
275 all around, with the back being either BFG or MT drag radials.
If the deal with the coupe that my dad found goes through... I'm about to start working on it.
I want a N/A motor that will make around 450 rwhp and 500 lb/ft of torque, which the above should, easily. But, I also want it to stop and turn like nobody's business, which the above should, easily.
Scary stuff.
Old 08-05-2006, 06:15 PM   #6
Here is the non 3 page long detailed list....
Kenne Bell 2.6L @ 19#
JLT CAI
302 VT Engine with stage 3 cams
DSS Level 5 Halfshafts
Seiman Dekka 60lb injectors
Dual Ford GT fuel pumps
Upgraded fuel rails
Gords Heat Exchanger with dual SPAL fans
Complete Evans Cooling kit (water pump, oil cooler, radiator, oil pump, oil filter reloactor)
Mid length headers...bassani I think
Complete Maximum Motorsports Grip in a box kit...front and rear
Custom Fabbed Strut Tower Brace
Upgraded Coils (forgot the name, just saw them in a mag yesterday)
Old 08-07-2006, 12:10 AM   #7
I just have to say that whatever it is you all want, obviously some of you REALLY know what you want, GO GET IT ! Live everyday like its your last!
With those setups, can you imagine the fun you could have. Smokin fast, turn and stop on a dime...I mean...there is a time and place for everything right?
Old 08-07-2006, 12:47 AM   #8
Thomas91169's Avatar
VT 5.4L Forged Shortblock/Rotating Assembly
Built up 4V Heads with Race Cams
2.6L KB
100 Shot of Direct Port Nitrous for ****s and Giggles
More Than Sufficient fuel system(cobra tank+pumps, injectors)
Viper Spec T56(6spd) Kit from D&D performance
Built 31spline Rear end w/Eaton Posi and whatever gearset is best for a 6spd with my mods.
Full Race Suspension(basically everything under the car that can be modded, modded)
Smog Hookup :pnoid:
and lots of dyno time.
so basically a personal loan for 15k ought to do the trick.
i have an excel spreadsheet with every mod for this car i can think of, and whenever i think of a new setup, i just formulate the prices and add them up and see what it comes out to. right now, the setup listed above without the suspension, dyno time and fuel, is almost 16k$.
-Thomas-
Old 08-07-2006, 04:41 PM   #9
bbunt302's Avatar
Give me the 25k or so and I'll get right on it...
Scary stuff.
Old 08-07-2006, 06:55 PM   #10
yeah, and that place is called college.
-Thomas-
Old 08-09-2006, 07:23 PM   #11
Region: Hawaii
Since we are talking dreams,
-Brand new "World Products" 5.4 Aluminum Block 6-bolt billet mains with alot more material to bore.( some one needs to step up and start making these)
-Punch it out to a 351
-Titanium Rods, Pistons
-Billet crank
-Brand new aftermarket heads(If anyone ever decides to make some)
-nasty blower cam
-dry sump oiling(the z06's are running it)
-Viper spec T56
- built, braced, shortened and welded ford 9inch rear, with a mini-tub so my 335's can clear the fender's on my 99
-5 link rear with a torque arm, tubular front k-member with griggs racing SLA system
-Aeromotive fuel system
-A Whipplecharger 5.0 liter twin screw supercharger
I dont think this would be streetable though
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 08-09-2006, 09:25 PM   #12
Kiljosh's Avatar
Poked and stroked 4.3l with all forged internals, 8.5 CR
TMA Turbo kit, 18 psi
Aluminum FMIC
Full MM Suspension Package w/ Tubular A-Arms and K-Member
Fully built 8.8 rear with 3.55's and a Detroit Locker
Bulletproof T-5 or else
3200 Stall Converter and race-spec valvebody.
Im happy with the rest but I could also use some rims, a cobra front bumper, ABC lip kit, Bassani Mufflers...yadda yadda..
I also would prob swap my ported stock heads for a nice set of Aftermarket Aluminum ones if they ever make em..
Old 08-09-2006, 09:44 PM   #13
MonteCitan's Avatar
zzp built transmission w/2800 stall converter
stage 2 intercooler
2.8" pulley with a safe tune
cam + lightweight drivetrain
= high 12s in the regal..
for the mustang.. roll cage + SC and a good tune = hopefully pushing 10s..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-09-2006, 09:48 PM   #14
i just want mine paid off first.... which is soon. wish i was born rich instead of the good looks i got!
white 98 gt is offline   Reply With Quote
Old 08-10-2006, 12:32 AM   #15
^^^eh, i like building credit. its good to have the mindset of spending only what you make, itll save your *** from paying lots of $ in interest in the long run, but unless youre born into it, youll never be able to buy a house with cash.
-Thomas-
Old 08-10-2006, 01:08 AM   #16
VT 5.4L billet motor
2.8L KB 25psi
150 Shot
Ford gt pumps in cobra tank, 60 lbs injetors
c4 tranny
Built 33spline Rear end
Qa1 full suspension ,10 point roll cage
When modding a car from the start: (order of mods list for best results!!!) RGR Pre-2005 V6 Mustang 150 07-05-2014 09:56 PM
Share your car! year, mods, color, miles, etc.. MonteCitan Pictures and Videos 327 06-08-2014 02:31 PM
fast and furious 3- fast food run Kyle The Bar 7 04-13-2006 12:56 AM
Summer Mods List coolstang Pre-2005 V6 Mustang 14 05-18-2005 04:37 PM
Let me share this with you Ken The Bar 3 03-19-2004 06:08 PM
11:01 PM
