speedometer calibration question - Mustang Evolution
Old 08-14-2006, 07:44 PM   #1
Racin02GT's Avatar
Send a message via AIM to Racin02GT
Question speedometer calibration question
I installed 410's in my GT about a month ago and i was at work one day (ontario mazda) and i was curious... i hooked my car up to the scanner (same as a Ford scanner) i tried to recalibrate my speedo using the reprogram function... it would not let me go as high as 410's, it says the limits are 325's to 329's... so i was wondering what would happen if i changed my tire size (would it throw my ABS off or make traction control act funny). Any ideas or suggestions?
Racin02GT is offline   Reply With Quote
Old 08-14-2006, 07:55 PM   #2
MonteCitan's Avatar
Re: speedometer calibration question
yes it would throw off your ABS workings -- I used a diablosport handheld to program mine.. that allowed me to change to 4.10 gearing..
btw how do you like the 4.10s? I never got a chance to try mine out
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-14-2006, 08:16 PM   #3
Racin02GT's Avatar
I love em... I was debating between the 373's and the 410's and everyone I talked to told me to go with the 410's cause if I got the 373's I would want more and just end up buyin the 410's anyways... got a good deal on em... got em from mustang tuning for $150 and spent the extra $50 on a full bearing kit... I installed em myself so that cut cost so all I have to do is calibrate my speedo.
Great first of many to come mods.
Old 08-14-2006, 09:01 PM   #4
Zim
You want to **** me?
Zim's Avatar
try searching for the speedcal from brothers performance.... That will get it dead on, it just attaches to your transmissions VSS (vehicle speed sensor) and changes the resistance sent to the actual guage so it corrects it. Its like 85 bucks, but worth the money. its only about a 30 minute install.
I like toys
Old 08-14-2006, 10:56 PM   #5
Racin02GT's Avatar
I was thinking of just getting an Xcalibrator instead of spending the exrta $80 I can just do it all with that...as soon as I get the funds together:burnout:
Old 08-21-2006, 07:41 AM   #6
In a mustang the ABS is a seperate module, it measures wheel speed at all 4 wheels and changing gears will not throw it off.
The dealer tools do not have enough adjustability range. You need an aftermarket chip, tuner, or speed cal to fix your speedo.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 08-21-2006, 03:50 PM   #7
Racin02GT's Avatar
i fixed it ... when i tried to do it at the dealership about a week ago and it quit the calibration half way through and blanked out my PCM ... so i loaded the as built data into the WDS and tried it again and when i went to recalibrate the pcm for the gears it said that there was no stored gear ratio... so i typed in 410'S and it took it2: ... so i was like ok and i let go through and reprogram mode and then took it out on the highway and it was right on didnt even have to change the tire size
need help asap!!! speedometer Senorjizzy Pre-2005 V6 Mustang 4 06-29-2010 06:47 AM
How do you figure out Speedometer calibration value? Horse Pre-2005 V6 Mustang 16 02-26-2010 09:10 AM
2000 v6 speedometer question CHILE10_STANG Pre-2005 V6 Mustang 2 07-25-2009 09:10 AM
help with speedometer roach 1996-2004 Mustang GT 2 06-20-2009 07:29 PM
v6 speedometer help. 01stang232 Pre-2005 V6 Mustang 5 01-13-2007 08:20 AM
05:27 PM
