Fuel - Mustang Evolution
Old 08-22-2006, 10:09 PM   #1
Send a message via AIM to 98StangGT
Fuel
So I filled my car up with premium gas 93, and its idles alot better, but still notice lil bit in throttle response, could be fule filter? or fuel pump?
Trey
98StangGT is offline   Reply With Quote
Old 08-22-2006, 11:04 PM   #2
Thomas91169's Avatar
Re: Fuel
a little bit of what? hesitation?
run some seafoam through the motor, then change out plugs and filters(oil, fuel, air).
automatic? could be tranny hesitation(4r70w normal sucky behavior)
-Thomas-
Old 08-23-2006, 03:42 PM   #3
Re: Fuel
Its a Standard and yes hesitation when its throttled, I did put seafoam in the engine a couple weeks ago, but did not change out plugs, and filters
Old 08-23-2006, 05:02 PM   #4
Re: Fuel
hrm, definately change out the plugs after a seafoam. 98's have plug wires correct(as 99+ get Coil on Plug), so id check those as well.
ive always found stumble/hesitation to be caused by igntion/timing, rather than a fuel problem.
-Thomas-
Old 08-24-2006, 08:53 AM   #5
Re: Fuel
fuel filter, plugs, plug wires, inspect coil packs. That might make all the difference. Start small and work your way to the harder more expensive items but DEFINATLY change the fuel filter EVERY year.
Old 09-11-2006, 12:28 AM   #6
Re: Fuel
I would go with changin the fuel filter, spark plugs. I know in my 2000 ford F-150 4.2l v6 i change my fuel filter every 15000 miles and it has 142000miles with a lot of upgrades and no problems.
bosscityboy86 is offline   Reply With Quote
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Not getting Fuel!!! Blt4dtuff 1979-1995 Mustang GT 5 05-29-2008 03:43 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
Fuel.. etc. Laser02 Pre-2005 V6 Mustang 3 11-16-2004 09:10 PM
08:09 AM
