What Rpm with 3.73 gears at 80 mph? - Mustang Evolution
Old 08-23-2006, 09:01 PM   #1
I have and 03 GT 5 sp. convertable. I am thinking about going to 3.73 gears or 4.10. I do some highway driving and don't want to kill all the gas milage.
With the stock gears I am turning around 2100 to 2200 at 80 mph and would like to know what others are seeing with 3.73 and 4.10 gears at 80.
Thanks for the help.
microflight is offline   Reply With Quote
Old 08-23-2006, 09:29 PM   #2
Re: What Rpm with 3.73 gears at 80 mph?
2750.............well, in between 2500-3000
Kyle is offline   Reply With Quote
Old 08-23-2006, 09:40 PM   #3
Look here.
http://www.mustangevolution.com/foru...ula-22451.html
JROC is offline   Reply With Quote
Old 08-23-2006, 11:41 PM   #4
Thomas91169's Avatar
no way.
on my GT, with stock 3.23 in 5th gear im at 2,000rpm@80mph.
with 3.73's and the same rear tire circumfrence, it will be around 2400rpm@80.
4.1's would put you at 2800rpm@80mph.
-Thomas-
Old 08-24-2006, 07:12 AM   #5
if you do 50/50 city/hwy you wont hurt the milage much at all, you will pick up a bit in town probably.
Old 10-04-2007, 10:32 AM   #6
Snake 42's Avatar
Originally Posted by Thomas91169 View Post
no way.
You must have lower (3.08's or 2.73's) in your car. I'm running stock 3.08's in my automatic and it turns 2000rpm at 70 mph. That's with stock BFG tires and 18" wheels so with 3.73 gears it should turn about 2250rpm at 70. Other than changing gears the only way I know to get real close is to determine exactly what gears are in the car now, what the final drive ratio in the transmission is, and what the circumference of the rear tires is and then spec it out
Snake 42 is offline   Reply With Quote
Old 10-04-2007, 10:46 AM   #7
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
my car on the stock wheels and tires turned about 2400 in 5th at 70 with 3.73. With the 3.27 gear it turned around 2000 in 5th
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 10-04-2007, 10:49 AM   #8
Y2E0L0L5OGWT's Avatar
3.55's in my 05 run about 2250-2300 rpm between 70 and 80...I would expect 2400-2500 with 3.73's, and like 2700-2800 with 4.10's...
Old 10-04-2007, 02:45 PM   #9
hottcobra's Avatar
I have 4:10s in my car and it turns 3000+ at 80mph
Old 10-04-2007, 03:50 PM   #10
bullitt482's Avatar
But you are an auto /\ :yup:
2200 ish at 70 here with stock size tires and stock 3.27's
2001 GT 5 speed
01 Bullitt
Old 10-04-2007, 06:20 PM   #11
you have to know the tranny gear as well as the rear end and tire size to do the math, its a percentage not a constant.
Old 10-11-2007, 10:35 PM   #12
Scut95's Avatar
i turn about 2750 at 80 in my car with stock tires and 3.73's....my dads 2000 GT turns 3000 at 80 with 4.10's and stock tires...both cars are stick
Old 10-16-2007, 09:22 PM   #13
Fishers Stang's Avatar
if ur going to do 80 on the roads most people dont care about the price they will pay for mpg.... i would be more worried about the $200 + fine u will get for speeding. btw i am at about 2200 rpm in the explorer @ 70mph.. in the mustang @ 70mph is about 1800 rpm
Charles
Old 12-27-2007, 02:32 PM   #14
I don't know about 80mph but I redline at 120 in 4th gear
jt2000gt is offline   Reply With Quote
Old 12-28-2007, 01:31 PM   #15
Herbstang's Avatar
About 2400 Don't really pay much attention to the tach when I'm doing 80
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
what rpm are you running with your gears stang_gang 2005-2010 Mustang GT 11 04-23-2008 07:07 AM
Hesitation at 40-50 MPH mustang2002 Pre-2005 V6 Mustang 8 05-03-2006 07:51 AM
Estimate using MPH... Stang_1973 Pre-2005 V6 Mustang 6 12-16-2004 07:59 AM
digital MPH??? jimmy_beaner Pre-2005 V6 Mustang 8 08-31-2004 02:13 PM
08:14 AM
