Octane booster - Mustang Evolution
Old 09-09-2006, 11:04 PM   #1
Send a message via AIM to 98StangGT
Octane booster
My car has a bad idle, so I thought I would try some octane booster, if this works, will it only fix it temporary, to where if i run out of gas, when I refill I have to always add the octane, or does it fix it permanetly??:confused
98StangGT is offline   Reply With Quote
Old 09-09-2006, 11:10 PM   #2
Danger Dude's Avatar
Re: Octane booster
Octane booster is a waste. It is Toluene. You would need 10 bottles to go up 1 octane point. It takes a gallon to make 2+ points. You could go to a hardware store and by a gallon and save like 30 bucks at the cost of one bottle of octane booster or better yet just get mid grade gas.
Old 09-09-2006, 11:14 PM   #3
Re: Octane booster
ive been puttin reg before, now im putting 93, should I try mid? or it wont make a difference?
Old 09-09-2006, 11:31 PM   #4
Re: Octane booster
You have other issues. In the morning this needs to be discussed what might be the problem. I am out for the night
Old 09-10-2006, 01:01 AM   #5
Re: Octane booster
Check your MAF and IAC, clean if necessary. Just run mid grade gas unless you have a tune requiring higher octane. Octane booster is a rip off, but some also clean injectors a bit. Just my opinion.
In2dreamingbig is offline   Reply With Quote
Old 09-10-2006, 02:00 PM   #6
Thomas91169's Avatar
Re: Octane booster
werd, the real deal is tuolene, found at your local home depot. i used to have the formulas for what amounts to add to what levels in your tank(IE full, half, etc) per what octane rating you were already using to equal what octane you want to accomplish. that was back in my dsm days where 91oct+22psi=no timing=no powah.
but if youre having idle issues, it is not due to octane/gasoline you are using. id run some seafoam through the motor and change plugs/wires afterwards. then try things like fuel filter, maf clean, iat clean, etc.
-Thomas-
Old 09-10-2006, 07:51 PM   #7
Re: Octane booster
You can get Toluene in any Hardware store, Lowes or Home Depot. It is about $10 a gallon. Toluene is what is used to increase octane. What is a joke is stuff like Octane 104 which is in only a pint of toluene which will only boost your octane 0.4 points but a gallon of Toluene will boost a 15 gallon tank of gasoline about 1.8 points. Very close to 2 full points.
I have the formula the petroleum industry uses when mixing fuel. Let me see where I saved it. Here we go
Here are some Toluene ratios. These figures are based on starting with 93 octane gas in your tank. 1st col.=tank size. 2nd = expected octane 3rd= ammt. of toluene to add to tank..
15.7 ; 95 ; 1.3gal
15.7 ; 94 ; 0.6gal
15.7 ; 93.5; 0.3gal
Convert gallons to quarts
1.3 gal.=5.2 qts
0.6 gal.=2.4 qts
0.3 gal.=1.2 qts
« new exhuast | Fuel »
87 vs 93 octane tune....... outlawfrog 1996-2004 Mustang GT 12 11-16-2009 07:52 PM
octane booster hurt my car Charlie-O 2005-2010 Mustang GT 34 08-09-2009 07:09 PM
V6 Mustang Brake Booster Problems Brent Pre-2005 V6 Mustang 24 11-05-2007 08:38 PM
Vacuum booster Black Panther Pre-2005 V6 Mustang 2 02-12-2007 09:45 PM
What octane to use chamillionaire Pre-2005 V6 Mustang 8 03-27-2006 09:34 AM
12:52 AM
