How to tell what gears you have...? - Mustang Evolution
Old 09-10-2006, 02:09 AM   #1
Can you determine what gears you have without pulling the ring and pinion and counting teeth? If it's stamped on the gears can you see it with rear-end cover off?
I bought my car used with many bolt-ons but not sure what gears I have. I want 4.10's. Thanks all!!
:drive:
In2dreamingbig is offline   Reply With Quote
Old 09-10-2006, 09:18 AM   #2
Racin02GT's Avatar
Send a message via AIM to Racin02GT
Re: How to tell what gears you have...?
there should be tag on the rear diff. cover(held on by one of the cover bolts)... there is one tag that has the recommended gear lube to use and the other should have a number like 327 if its a GT. thats what mine had
Racin02GT is offline   Reply With Quote
Old 09-10-2006, 02:52 PM   #3
Thomas91169's Avatar
lemme re-word that, i know what you were trying to say and even i was confused.
make a mark ad the driveshaft and conjoining flange. mark top of tire. rotate tire and observe how many times the mark on the driveshaft hits the mark on the flange per one full rotation of the tire. its great for whole numbers, but to do actuals, its a little tricky. 3.23's would be 3 full rotations witht he mark resting 1/4 of a rotation after hitting the 3rd rotation. 3.55's would be 3 full rotations and the mark resting halfway through a full rotation. 3.73's would be 3 full rotations with the mark resting 3/4 through a full rotation. and so on and so forth.
or no matter what, you can always get some 4.1's and slap them in there and know what you have without all the brainwork.
also into, auto/manual and what rpms' do you tach doing 80 would be the easiest way.
-Thomas-
Old 09-10-2006, 06:37 PM   #4
MonteCitan's Avatar
That's what I meant
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 11:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 09:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 07:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 08-01-2005 12:05 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 05:02 AM
06:32 AM
