best plugs - Mustang Evolution
Old 09-11-2006, 11:20 AM   #1
best plugs
Wut's up i'm wondering if anybody could help on deciding wut plugs should i get for my mustang. i wanting something for a n/a setup and plan on doing a lot of mods to the ar in the next few weeks and wondering wut would be the best plugs to choose. thanks for the help.
bosscityboy86 is offline   Reply With Quote
Old 09-11-2006, 11:24 AM   #2
Danger Dude's Avatar
Re: best plugs
Motorcraft or Autolite are simple the best for the Ford engine. Champions and Bosch are not advised and can cost you more in the long run. Also dont believe the claim of Super dooper plugs like splitfire or Accel plugs they do not do anything special that a normal plug does.
Old 09-11-2006, 11:29 AM   #3
Re: best plugs
thanks for the quick i'll keep that in mind.
Old 09-11-2006, 04:56 PM   #4
bbunt302's Avatar
Re: best plugs
Autolite. You should be able to get 'em at Walmart for dirt cheap.
Scary stuff.
Old 09-11-2006, 06:09 PM   #5
Re: best plugs
I agree with bbunt302, and Corey. I was using my dads truck one day. Its a 1997 F-150, and it started to run like crap, and the check engine light came on. So I limped it to the Ford dealership, and it turned out that the problem was my dad had gotten the spark plugs change about a year ealier, and they used champion spark plugs. The people at the Ford dealership said that you should only use autolite plugs in Ford products because Ford own Autolite. They told me that Dodge owns Champion, and the plugs that they make that fit F-150's doesn't work the same as the Autolite plugs intended for the F-150. I can't remember what spark plug company they said that GM owns, but I believe they did tell me. The spark plugs didn't hurt the truck I don't believe, they just burnout prematurely.
JROC is offline   Reply With Quote
Old 09-11-2006, 06:16 PM   #6
Re: best plugs
GM = AC/Delco
Old 09-11-2006, 06:19 PM   #7
Re: best plugs
Originally Posted by Danger Dude View Post
GM = AC/Delco
Thanks.
Old 09-12-2006, 12:53 AM   #8
Thomas91169's Avatar
Re: best plugs
NGK.
-Thomas-
Old 09-12-2006, 12:54 AM   #9
Re: best plugs
Originally Posted by Thomas91169 View Post
NGK.
He's talking N/A here...doesn't need to get all fancy with the NGK or Densos or anything like that (BTW...NGK TR6ix Irridiums @ .032-.034 work great on our cars )
Old 09-12-2006, 01:25 AM   #10
Region: Hawaii
Re: best plugs
Check these out. Brisk USA Enterprises, LLC. They are kind of pricey, but they have been praised in 5.0.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 09-12-2006, 03:00 AM   #11
Re: best plugs
i use NGK in everything. just stuck one in my lawnmower, the grass didnt stand a chance.
-Thomas-
Old 09-12-2006, 06:02 AM   #12
Re: best plugs
NGK.
I would not run NGK's in a N/A mustang. It is not necessary.
Old 09-12-2006, 06:08 AM   #13
Re: best plugs
Sorry but magic plugs are bullcrap. A plug does nothing more than deliver a spark from a coil pack on modern Mustang. They have not hidden internal nuclear reactor or magic fairy dust in them to boost or make a super spark.
The problem here is you are quoting a manufactures ad that was in 5.0 mustang which is a paid advertiser.
Remember this 95% of advertised claims of better mileage or increased HP on anything like plugs, wires, oil, oil additive, exhaust, TB spacers, fuel additive, swirly makers is either hyper or a lie.
Old 09-12-2006, 06:11 AM   #14
bbunt302's Avatar
Re: best plugs
I don't care if I had a 1300 hp Turbo 500+ cube motor, I'd run Autolites. NGK, Denso, etc are nothing more than effective marketing.
Scary stuff.
« Fuel | IAC »
Spark Plugs drkchocolate07 Pre-2005 V6 Mustang 9 05-10-2009 01:29 PM
Best plugs for stock Foxone Pre-2005 V6 Mustang 18 07-12-2008 05:32 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 06:36 AM
anyone see anything wrong with these plugs? jimmy_beaner 1996-2004 Mustang GT 17 03-12-2008 09:37 PM
Spark Plugs megax29 Pre-2005 V6 Mustang 20 10-09-2006 05:36 PM
02:24 PM
